rpo's
here are the rpo's and descriptions that are on my 99 formula...there are a few that i couldnt find, and a few that i have questions about...
AAA FACTORY TINTED WINDOWS AH3 ADJUSTER, 4-WAY MANUAL, DRIVER SEAT AK5 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER AK9 RESTRAINT SYSTEM, RR SEAT, SHLDR, RETR, 3 POINT AU0 LOCK CONTROL, REM0TE ENTRY AU3 LOCK CONTROL, SIDE DR, ELEC A31 WINDOW, POWER OPERATED, SIDE C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED FE2 SUSPENSION SYSTEM, RIDE HANDLING GU6 AXLE REAR, 3.42 RATIO G80 AXLE POSITRACTION, LIMITED SLIP IPB TRIM, INTERIOR DESIGN J65 BRAKE SYSTEM, POWER, FRONT AND REAR DISC K43- ???? LS1 ENGINE, GAS, 8 CYL, 5.7L MM6 Transmission, Manual 6 Speed OD MN6 TRANSMISSION, 6-SPEED MANUAL NB7- ???? NG1 EMISSION, NEW YORK, MASSACHUETTS, CONNECTICUT NP5 STEERING WHEEL, LEATHER WRAPPED PA6 WHEEL, STYLED, PAINTED QFZ TIRE ALL, P245/50ZR16 R9P- ???? R7X SECURITY PACKAGE STE PLANT CODE - ST. THERESE, PQ, GM OF CANADA T78- ???? UA6 THEFT DETERENT SYS UK3 ELECTRONIC SYSTEM, ACCESSORY CONT (Steering wheel radio controls) U75 ANTENNA, POWER, RADIO VM3 LABEL, CONSUMER, CONTAINS BPR IMP STANDARD V73 VEHICLE STATEMENT, USA/CANADA WS9 MODEL CONVERSION, FORMULA W55 ENTERTAINMENT SYSTEM – "MONSOON" ETR AM/FM STEREO, COMPACT DISC, EQUALIZER, REMOTE CD PREWIRING, 10-SPEAKER SYSTEM - COAXIAL W66 MERCHANDISED PKG, FORMULA 11U PRIMARY COLOR , EXTERIOR, PEWTER METALLIC (91) 14B TRIM COMBINATION, CLOTH, LT GRAY (B) (92) 14I Interior Trim, Very Dark Gray 15A STRIPE COLOR, ACCENT, MED GRAY MET, (91) 6ZL- ???? 7ZL- ???? 8TH- ???? 9TH- ???? 1.my windows arent tinted. if they are its the lightest tint ever designed. 2.what does that change on the car. what are the emissions like up there? im just wondering if it hurt performance at all. 3.it doesnt say those tires are speed rated...does that mean the car is governed? 4.the seats are like a dark black cherry looking color, and leather. not cloth. 5.there is no stripe on the car. lol if anyone can help with this, please do. |
Re: rpo's
on the RPO sheet, look at the VIN #.. does it match your car? Just make sure, perhaps
Re: rpo's
Did you buy this used???? As stated above check vins....
Re: rpo's
ill check on that...but the sheet with the rpos is affixed to the driver side door...how would they be different? im almost positive the door is the original one. lol.
and yes it was used. |
Re: rpo's
ok, checked the vins, and theyre the same. and on one of the other stickers below the rpo one, it says front and read tires are Z rated and spare is M...so that means theres no governer right? since the tires are speed rated..?
Re: rpo's
R9P seems to be a Control Sales Item (some kind of mandatory code for ordering the car)
K43 Generator 102 amp NB7 Emission system california, TLEV T78 headlamp control delete Below is for the suspension springs: 6ZL : SPRING, COMPUTER SELECTED, FRONT, LH 7ZL : SPRING, COMPUTER SELECTED, FRONT, RH 8TH: SPRING, COMPUTER SELECTED, REAR, LH 9TH: SPRING, COMPUTER SELECTED, REAR, RH |
Re: rpo's
Re: rpo's
