View Poll Results: What do I do
Tear down engine
0%
Try to sue summit for costing me all this grief
0%
Drive it into a lake and call geico
0%
Send it
0%
Voters: 0. You may not vote on this poll
Please help! Did summit ruin my engine?
Old Jun 11, 2021 | 12:06 PM
theknockout93's Avatar
LS1, 02 Camaro. I ordered a stage 1 camshaft from summit, I asked if I needed to swap the valve springs, the tech said NO! 3 months later, car won't run properly. I performed all troubleshooting steps, and I've come to find the valve springs HAVE to be swapped. The stock springs are only good to .520 max lift. The cam has .600 lift on the intake.
​​​​​​Summit listened to the call, and admitted they messed up, however they are pretty much leaving me out to dry. I'm trying to figure out if there was coil bind. If there was, Im reading that the camshaft, lifters, pushrods, and rockers could be damaged. Please help. I'm afraid I'm gonna have to completely tear this motor down again.. thanks for helping out a youngster!
Old Jun 11, 2021 | 02:38 PM
Re: Please help! Did summit ruin my engine?
Your post went into the “approval” queue, which is an action taken by the software. Not sure why, but several of your posts have required moderator approval. I honestly don’t know why.
If there's a lesson to be learned here, it’s that you don’t rely on parts house techies, live or on the Internet, for critical build info. You need to research procedures, maybe ask questions on a forum like this, etc. That’s just the smart way to do it. Checking springs for coil bind on a cam swap, before install, is a basic requirement. Doubt you have any recourse against Summit. And I don’t think there's much point to your poll.
Old Jun 18, 2021 | 11:31 PM
Bigstick's Avatar
I been in your shoes and learned the hard way with this situation your will have to remove motor and camshaft and inspect cam ,valve train also there are companys that have cam kits you can get kits with matched cam, lifters,pushrods,springs, and timing sets
Drkbwtiprfm25
Jan 2, 2010 02:59 AM
BLUETOPTA
Jun 25, 2006 12:23 AM
KyleBlue85Iroc-Z
Advanced Tech
Apr 27, 2006 06:12 PM
LT1CST
Nov 7, 2003 12:58 PM
KCFormula
Advanced Tech
Nov 24, 2002 07:47 PM
