Convince me to upgrade my valve springs
Old Jun 22, 2006 | 05:00 PM
BLUETOPTA's Avatar
Exclamation Convince me to upgrade my valve springs
In my 1995 LT1 I have been running the comp cams cc305 cam. Its intake and exhaust lifts are .510 / .510. I also have these combined with 1.7 rocker arms.
For springs right now I have the LT4 spring kit. It is rated to .525 lift. Right now I am running more lift the what the spring is rated at. I have been running this combo for over 5000 miles. It runs pretty good. My car has heads and cam, and at the track its 1/4 MPH is only like 106 or 107.
-Could better springs get me more HP and better 1/4 MPH?
Let me know
Thanks,
Old Jun 22, 2006 | 05:06 PM
RE AND CHERYL's Avatar
Re: Convince me to upgrade my valve springs
Why should we convince you to change valve springs??? Your running .578 lift on springs that are only good to .525. I'm surprised you haven't bent pushrods and trashed your roller lifters or cam.
Will the right valve springs get you more power? I doubt it.
Will the right valve springs eventually same the top end of your engine? YES!
Old Jun 22, 2006 | 05:07 PM
BUBBA's Avatar
If your springs are not correct, you will probably suffer on top end due to float---and you might also be jeopardizing your entire engine integrity. I'd get some good double springs and have some piece of mind.JMHO
Old Jun 22, 2006 | 05:59 PM
BLUETOPTA's Avatar
Car runs good and fine the way it is. Just took valve covers off to fix a leak. Everthing looks ok.
I am a little dissapointed by my 1/4 MPH. If new springs will help me pick up some power I will change them.
Old Jun 22, 2006 | 06:22 PM
94StockFormula's Avatar
With that spring/cam combo you 1/4 time will soon be irrelevant.
Old Jun 22, 2006 | 06:25 PM
Z28Vert19's Avatar
Smile Re: Convince me to upgrade my valve springs
if you change them you will be setting your self up for more power later on and you wont have to touch them. I think your pretty lucky to not have bent a rod yet. kinda pushing it arent you? Id rather spend 200$ on springs than 2000$ on rebuilding the top end. JMHO
Old Jun 22, 2006 | 10:35 PM
marshall93z's Avatar
WOW....just wow!
Change your springs.
Old Jun 22, 2006 | 10:46 PM
HardcoreRM125's Avatar
your lazyness will **** you in the long run
Old Jun 23, 2006 | 08:24 PM
Don't worry. you'll got plenty of time to pick up power when you rebuild the engine after it drops a valve. Just because you haven't had a problem yet, dosn't mean you won't. And when you do, your gonna drop a valve and possibly trash the motor.
If we tell you you'll pick up power, will you change the springs?
Old Jun 23, 2006 | 08:27 PM
Mike96z's Avatar
I have Crane Cams 10308 springs on my cc468 and runs fine but I can't find specs on those double springs anywhere, not sure what lift limit is, sure it's at .600/.600 and my cam is .584/.579 w/ stock rockers, im running 1.6rr.
Old Jun 24, 2006 | 02:33 PM
Casey_SS's Avatar
If you change the springs, it'll be a 10 sec car....guaranteed. Feel better now?
You've already done the math and know what needs to happen...don't be a dumb*ss. Most of us work very hard to build these cars up and keep 'em running well....you won't find a lot of sympathy or support for running yours in a combination that you know d*** well is just a time bomb.
Old Jun 24, 2006 | 03:45 PM
Mike96z's Avatar
Change them or you'll be buying a whole new block, that's guaranteed!!!
Old Jun 25, 2006 | 12:23 AM
Can I buy your block once you blow it up? I need a nice conditioned block to finally start this forged low-comp 383 project. Then I just need a few more thousand for a nice ATI, or turbo, etc.
I will give you $250 for the block.
QuickSilver02
Apr 7, 2015 11:12 AM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
