obdI or obdII?
Old Apr 12, 2007 | 09:09 PM
BMoney's Avatar
obdI or obdII?
I just got a 95 Camaro, 3.4 v6 a4 car. my question is how do I know if its a obdI or obdII ? I have a 96 formula and I know thats a obdII, are the computers different looking? thanks Brian
Old Apr 12, 2007 | 09:18 PM
93LEETZ's Avatar
should be obd1 with obd2 looking connector.. when i had my 95 3.4L m5 car it was that way and i hooked up a obd2 code reader but it wouldnt power on. i ended up using a tech2 to read the codes. which was capable of reading obd1 and 2.
Old Apr 12, 2007 | 09:56 PM
BMoney's Avatar
didnt they start switching sometime in 95? is it possible that mine has obdII. cause it does have the same connector as obdII. thanks
Old Apr 12, 2007 | 10:26 PM
Dave89IROC's Avatar
look at the emissions label under the hood, it will say obd 1 or obd 2
although, IIRC, the 95 3.4 was obd 1 with the obd 2 connector, and the 95 3.8 was obd 2
Old Apr 12, 2007 | 10:37 PM
3.4s were OBD-I. 3.8s were the only OBD-II in 1995 as Dave says.
It's just the DLC you are seeing that is different. It's the same on the LT1 1995s.
Old Apr 13, 2007 | 10:28 AM
BMoney's Avatar
thanks guys thats what I was looking for!
Old Apr 17, 2007 | 10:35 AM
BMoney's Avatar
anyone know what kind of code reader I will need?
thanks Brian
Old Apr 17, 2007 | 03:16 PM
thanks Brian
OBD-I reader or scanner with the proper adapter cable for the 16 pin DLC. You could buy one that does OBD-I and II that would take care of both your cars. Get a scanner-they do more.
Old Apr 17, 2007 | 03:55 PM
moparman's Avatar
Check Actron and Autoxray.
Old Apr 18, 2007 | 02:02 PM
BMoney's Avatar
thanks guys, im kicking myself in the butt, cause I just sold a snap on scanner (solus) a few months ago dirt cheap!
aj2494
Mar 12, 2015 10:17 PM
ollie-99
Feb 10, 2003 12:48 PM
SnkEatr
Feb 9, 2003 09:56 PM
96z
Feb 6, 2003 03:23 PM
blackhawk96
V6 Tech
Aug 27, 2002 07:17 AM
