high idle?
Old Feb 2, 2009 | 07:31 PM
freethrowchamp's Avatar
high idle?
i have a 94 camaro z28 with a lt1. when i start it up it idles at 2000 then falls down to 1500 when in park and neutral. in drive it idles at 1000 rpms. does that sound high? this is my first camaro. most cars idle like 600.
Old Feb 2, 2009 | 07:53 PM
Green96Z's Avatar
Check the throttle blades to see if they're sticking. I forget, but I think stock idle for an A4 is around 800.
Old Feb 2, 2009 | 08:00 PM
z28-4life's Avatar
It should idle lower....
Old Feb 2, 2009 | 10:37 PM
Check for vacuum leaks.
Old Feb 2, 2009 | 10:57 PM
Stock idle programming for the A4 is 650rpm in neutral and 550rpm in gear. In very cold weather (coolant temp at 3*F) the cold start idle speed in neutral is increased as high as 1,200rpm. And, the stock tach typically reads 100-200rpm higher than actual rpm.
Definitely idling too high.
Old Feb 2, 2009 | 11:41 PM
Slick_Sammy's Avatar
vac leak or maybe IAC valve (idle air control valve)?
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
