Electric Water Pump
Old Jan 8, 2013 | 12:15 AM
YBSTOCK's Avatar
Electric Water Pump
Just wondering what everyones opinion is on electric water pumps and also would it be possible to use the smog pump wires to the electric water pump providing i connected the right harness connector to the smog pump wires. Or would the computer shut the power off to the wires like it does to the smog pump. Smog pump is removed btw.
Old Jan 8, 2013 | 04:53 PM
parkers Z28's Avatar
Re: Electric Water Pump
I have got some mixed reviews about the electric water pump most people will tell you not
to use it on your daily driver ....
Old Jan 9, 2013 | 09:59 AM
bobdec's Avatar
Forget the smog pump idea (Air pump) . It's only activated during cold start for a minuet or two. You need to add a relay activated by +12v ignition on to feed the pump and/or a switch to activate the relay. Lots of places under the hood to pick +12 IGN. As far as electric Vs mechanical.. It's been beat to death search on ' pros cons electric water pumps ' . I run mechanical.
Old Jul 6, 2021 | 10:34 AM
cybern8's Avatar
members of this forum are just effing AWESOME!! thanks guys!!
(oops - this was supposed to go in https://www.camaroz28.com/forums/lt1...r-pump-888999/ ... no idea how i ended up here)
Old Jul 6, 2021 | 10:51 AM
You might want to check your own thread from yesterday. There are useful responses:
96KillaZ
Feb 9, 2006 05:28 PM
motownz
Jun 24, 2004 05:10 PM
KTamez
Mar 27, 2004 07:11 PM
hozb817
Jan 24, 2004 03:00 PM
