Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Is my fuel pump bad
Old Oct 12, 2008 | 08:48 PM
brannanjohn's Avatar
Is my fuel pump bad
can anyone share a list of steps that I can go through to determine if my fuel pump is bad?
Old Oct 12, 2008 | 09:00 PM
Expense95's Avatar
When you first turn the key to the run position, before starting, you should hear a fuel injection prime. If you dont hear it....try reading out the relay for voltage
Old Oct 12, 2008 | 09:12 PM
when i turn the key to the run position, the fuel pump makes a sound, but it seems different sounding than before. I went ahead a put a fuel pressure gauge on the schrader valve, and in the "on" position, I get no reading. Its almost as thought the line is clogged.
Old Oct 12, 2008 | 10:45 PM
Helpful hint....
They built F-Bodys from 1967-2002. There were numerous types and configurations of fuel pump setups. You need to add a "signature" with the basics info about your car - year, model, engine, tranny and any major mods. Without that into, people have to guess what car you are asking about, and you reduce your chances of getting accurate and helpful information.
Old Oct 13, 2008 | 12:07 PM
sorry about that. Its a 96 SS LT1 slightly moded, but nothing that should effect the fuel pump.
Old Oct 13, 2008 | 09:53 PM
Can you hear the pump run for a couple seconds when you turn the key to "on", as the first person to respond asked you, then shut down? If not, or if it sounds "different", use the fuel pump prine connector to power the pump. That will bypass the pump relay, and the PCM "permit" signal.
When you put the fuel gauge on it make sure the connector for the fuel pressure gauge has a pin in it that depresses the core of the Schrader valve. If it doesn't, you won't get any reading. In that case, you would have to pull the core out of the Schrader valve and hook the fuel pressure gauge up before you start it.
Old Oct 15, 2008 | 11:57 PM
ItalianSS's Avatar
When my pump started to go on my car, I first noticed this weird whining noise coming from the rear of my car, when the car was running. I then noticed a significant decrease in power when driving. When ever I drove slow, it was fine, but when I went to go give it some gas... it's like, it was being held back.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
