Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
ltcc question
Old Apr 5, 2011 | 09:12 PM
1badasZ's Avatar
ltcc question
do you still have to have a good opti for this to work? i just developed a high rpm miss for some reason and have been considering just swapping but if i have to use a good opti i donno if its even worth the trouble
Old Apr 5, 2011 | 09:29 PM
Re: ltcc question
Absolutely. The optical portion must still function correctly.
Old Apr 5, 2011 | 09:36 PM
1badasZ's Avatar
Re: ltcc question
it still cranks and drives its just the high rpm. all i did was change plugs and i went back n checked all connections and they seem ok and its still doing it. wont even make it to shift point
Old Apr 6, 2011 | 12:05 AM
Re: ltcc question
Did you check for arcing plug wires? Have you have the IC module checked? Have you scanned it for codes? Have you checked the fuel pressure?
Old Apr 6, 2011 | 01:16 PM
1badasZ's Avatar
Re: ltcc question
Icm, pump, regulator,injectors,coil are all new. I'm going to check for arcing wires tonight. If I burned one already Imma be pissed. Routed good far as I can see and have fire sleeves. Only thing I did was swap from tr6 to tr55gp gapped@.050. Was revving fine the day before but started noticing a miss after tune change so I changed plugs
Old Apr 6, 2011 | 09:41 PM
1badasZ's Avatar
Re: ltcc question
I did finally track down my exhaust leak which im hoping what was causing my lean/knock condition. The #1 header tube which is a slip tube was leaking its a%& off
DirtyDaveW
Mar 15, 2015 07:01 PM
mikey4play
Mar 15, 2015 11:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
