Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Crank no start help please
Old Feb 23, 2009 | 01:51 PM
Delirus's Avatar
just put an opti in a 94 camaro that was towed to my house car still wont start water pump went south and took out the opti so i replaced the water pump and the opti. have 36lbs OF FUEL PRESSURE HAVE SPARK AT THE PLUGS SHOT STARTING FLUID IN NOTHING HAPPENS YET IT BACKFIRES THREW THE EXHAUST AND THE INTAKE ignition module? i swapped out computers with my 97 ran for 4 secs like **** then shut off because of the vats pulled the plugs cleaned them . anyhelp would be great.. o and can you put an opti on 180 degrees off?
Old Feb 23, 2009 | 02:39 PM
mrmint69's Avatar
Opti can be installed incorrectly and will run like your describing. Putting the plug wires on wrong will also cause this.
Old Feb 23, 2009 | 03:02 PM
Delirus's Avatar
how is one installed wrong then? if the splines line up and it slides in?
Old Feb 23, 2009 | 03:57 PM
bobdec's Avatar
Only one way it will go together, it won't go in wrong unless you jamb it in with the key misaligned to get it incorrect. It's a PITA but if the key on the drive shaft is lined up with the slit in sprocket it slides in easily and sits firmly and flat against the timing cover mounts, no space and no need to force the bolts in. Recheck the wires with a meter if necessary. ref shoebox http://shbox.com/1/93-94_opti.jpg also opti checkout http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Feb 24, 2009 | 12:07 AM
mrmint69's Avatar
Check the plug wire routing and make sure they are on all the way on both ends and that the connectors are snug.
Old Feb 24, 2009 | 07:33 AM
Delirus's Avatar
DID THE JOB OVER LAST NIGHT JUST TO BE SURE EVERYTHING WAS DONE RIGHT TWIC IT SEEMS MY TIMEING IS OFF started with my 97 comp for a few secs then shut off cuz of the VATS leading toward a comp anyone have a 94 95 comp in jersey i could borrow for a few min just to be sure the corvette comp is a diff part number so i dont think it will work. i have 6 gm techs dumb founded right now including myself never seen this before
Old Feb 24, 2009 | 11:11 PM
mrmint69's Avatar
You say the computer from the 97 will let it start and run for a few seconds. Does it run as long with the other one?
Old Feb 25, 2009 | 11:46 AM
Delirus's Avatar
it wont start with the 94 comp at all thats the wierd part making me think its the ecm just wanted the boards op. befor i blow 100 on one
Old Feb 25, 2009 | 05:26 PM
Have you scanned it for codes?
It is far easier to incorrectly assemble the splined shaft than has been described. I'd estimate at least 10% of the unvented opti's are installed incorrectly because of this. But this error will not set a code. You need to check the codes to make sure the PCM is seeing the high and low resolution pulse signals from the Opti. If it isn't, it will set and code and will not start.
Old Feb 26, 2009 | 07:04 AM
Delirus's Avatar
no codes have everything and the new opti is vented by the way im just going to put a comp in nothing else left
Old Feb 26, 2009 | 09:22 PM
dookie454's Avatar
I put my FIRST opti on wrong TWO TIMES!! It was only about 30-45 degrees off but this was a 1996 style so might be different than your 94.
DO NOT LISTEN TO PEOPLE WHO SAY YOU CANNOT PUT AN OPTI IN WRONG! These people actually added 1-2 days of further investigation because of these comments I ignored the possibility that the opti could be installed wrong (can be more than just 180 degrees off too, I think it can be 30-45, 90, 180 off, anything really.
This was on a complete 383 rebuild so I was assuming I put the cam in wrong, anyway with mine installed wrong the opti did not sit completely flat against the timing cover it stuck out probably 1/16th of an inch.. not that much I didnt even notice it and it made it backfire and only kinda sputter fire for a second then stall. I only noticed it not sitting flat after purposly installing it wrong the THIRD time to see how noticable it was.. not very noticable!
On mine no matter what I did to line it up I couldnt cause the viewing angle was messing me up, I ended up using a Black Marker and puting the cam slot straight up then marking the cam chain cover with marker and marking the Opti shaft with marker and made sure they were in right...
After lining it up correctly it fired right up. Amazing!
Old Feb 27, 2009 | 07:45 AM
Delirus's Avatar
sorry but you really cant put an opti on wrong its keyed unless you jam it in ive done many never had a problem it only goes in one way
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jessie4tin
Jan 7, 2015 08:53 AM
1LEThumper
Jul 14, 2003 12:45 PM
