Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
code 41
Old Sep 2, 2010 | 11:48 AM
terryhotrod's Avatar
code 41
I have a 1995 lt1 with a code 41, anybody dealt with that before ?
Old Sep 3, 2010 | 10:26 PM
DTC 41 = Ignition Control (IC) circuit (open circuit)
Could be the white wire from the PCM to the IC module, the 12V power from the coil connector to the IC module, a faulty IC module. Use Shoebox's IC module test procedure:
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Sep 22, 2010 | 12:20 PM
The engine has just been rebuilt and everything checks out ok except the pesky code 41. My question is can the code 41 be disengaged as to be able to get a custum tune in the car?
Old Sep 27, 2010 | 01:05 PM
rskrause's Avatar
Moderator
The code prevent you from programming the PCM? I never dealt with that particular code, but it seems odd that it keeps you from uploading a program. Please elaborate.
Rich
Old Sep 30, 2010 | 12:01 PM
Question code 41
I took the car to Ed Wright Fast Chip in Tulsa and we worked on the code,chased it down to a voltage drop but ran out of time and couldn't go any futher until I fixed the bad wire! Now I got this bdas car that I can't get turned cause of a slight voltage drop! It isn't causing any malfuntions in anyway! just causing that pesky code 41 to pop off. Ed has since retired !!!!!! And in Okla city area I don;t know of anybody that is close to his skill level, wa, wa, SO my question is can I take the car to someone and get it tuned with the code 41 displaying?:
Old Oct 1, 2010 | 07:14 AM
rskrause's Avatar
Moderator
I never heard of a code that would prevent you from reprogramming. If that is what you are asking. One thing Ed Wright was famous for though was locking tunes. I hear he quit doing that at some point but I have seen some of his that were locked. If your's won't reprogram that is probably why.
Rich
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
