Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Access door to change fuel pump - 4th Gen
Old Sep 21, 2009 | 01:58 PM
  #61
cardo0's Avatar
The door is open.
Negative with the jig saw - moved to plan "B". I broke 2 jigsaw blades in less than 1 inch. Bought the biggest tin snips at Hobo Fake and cut the metal door out in 'bout half hour.
New questions. How do i reach the hose to tubing connections under the rear shelf metal but above the tank? Do i need to pull the pump and sending unit to access the flex hoses? Is there enough slack in the flex lines to pull up the fuel pump and sending unit? Or do i need to cut another "door" over the tubing lines?
cardo
Old Sep 24, 2009 | 05:58 PM
  #62
Kevin Blown 95 TA's Avatar
There's a few guys that had trouble getting the far one off, and they cut more metal away to access it, others just were able to get it off somehow. I know on mine it was extremely hard to get one of them off but I was able to do it somehow, I used the small plastic fuel line tools which are very compact and just need to be slid over the line, then popped into the fitting.
Old Oct 14, 2009 | 02:40 PM
  #63
MikeGyver's Avatar
Geez, I'm surprised you were able to cut that, especially since theres no edge where you can start at the back of the blades.
Old Nov 1, 2009 | 10:34 AM
  #64
I'm not sure why this thread was even necessary, when there was a thread already stickied.
I'll merge it, but it would have been easier if all this was put in the "sticky" in the first place.
Old Nov 15, 2009 | 04:32 PM
  #65
Wart Hog's Avatar
Cut mine today, My fuel level sending unit had quit and needed to be replaced. I decided while it was out to drop in a new pump as well. Local chevy dealer quoted me $535 to replace it. RIGHT!
I dig doing it myself.
Old Nov 16, 2009 | 03:42 PM
  #66
netooi's Avatar
So, I've not really done any metalworking stuff before, but this option seems really preferable than having to drop the tank...
I found a piece of sheetmetal at Lowe's for like $10.00, that I could cut the access door from... I've also got access to some heavy duty tin snips..
The part I am concerned about is properly creating the access door and sealing it up right.
Can anyone here go into a little more detail about this? What other things do I need?
What kind of screws would I need to get?
What type of sealant would be best to use for the door... I don't want to end up with carbon monoxide or fuel fumes leaking into my car.
Thanks a lot!.
Old Dec 6, 2009 | 08:44 PM
  #67
skipjobe's Avatar
I did mine about 3 years ago and have been back in there about 5 times. Gotta do it.
Old Feb 18, 2010 | 12:18 PM
  #68
ghost stripes's Avatar
has anyone else had trouble getting the fuel pump back in the tank ?when i drop it in it seems like it goes most of the way in and stops.i see the hump in the middlle of the tank how do you get it over that to where the pump goes all the way in ?
Old Mar 19, 2010 | 12:05 PM
  #69
sscott's Avatar
Did anybody replace the door with a hindge?
Old Mar 19, 2010 | 08:51 PM
  #70
1996greenZ28's Avatar
Talking
cutting the access panel was great. im a big fan of it now. it took me all of an hour to cut the hole take the lines loss and pump the 255 grantelli in. i was ver unsure about it before but i like it now incase something goes wrong again.
Old Apr 17, 2010 | 05:17 PM
  #71
sscott's Avatar
After you cut the access hole, how do unhook all those lines on top of the pump? I see one small rubber hose on one of the lines, but how do you get to the other lines?
Old Apr 17, 2010 | 09:11 PM
  #72
DirtyDaveW's Avatar
I'm not sure but I *think* you only have to squeeze the plastic tangs together on the side of the connector and it should slide off. Just like on the one end of the fuel filter.
Old Apr 18, 2010 | 06:49 AM
  #73
sscott's Avatar
It say's on Summits website that there was a major modification to install the Granitelli 255, any truth to that.
Old Apr 18, 2010 | 09:06 AM
  #74
DirtyDaveW's Avatar
Hmm... I just looked at that pump on their site. Looks like the normal 255 that everyone here typically uses. I think if you follow any number of writeups on it(installing/replacing the fuel pump itself), you'll be fine. Perhaps they say it's a major modification in reference to pulling the gas tank out. That would be labor intensive. This thread is about avoiding all that tedium plus allowing quick access for maintenance, upgrades and/or future replacements.
Old Apr 19, 2010 | 04:52 PM
  #75
sscott's Avatar
I just picked up a piece of sheet metal from Lowes, I think it might be too small, it's 6" X 24". Just to be safe, I'm going to return it for an 8" X 24" piece. I also picked up some self drilling 8 X 1/2 Truss washer lath screws. Anybody have any input on what size sheet metal I need and or screws for that matter. Any input would be greatly appreciated. Thanks.
