Whats everyone using for plug wires?
Re: Whats everyone using for plug wires?
Originally Posted by myslowcamaro
i know someone that sells spark plug wire sleeves. good up to 1200 degrees. many colors pm if interested. they have heat wrap too
They are definetly not the be all and end all of burnt wires..
Originally Posted by Sean94Z
I've had 2 different sets of sleeves on my car. One from Perfomrnace Distributors and one that I got from Thunder .. Both sets allowed wires to burn INSIDE the sleeves..
What was wrong with the MSD 8.5s? The Taylors are only 8mm.
Originally Posted by CALL911
Just curious as to of the type/brand of plug wires people are using with their forced induction cars? I currently have the MSD 8.5 mm wires, but they are a little worn, and was considering changing the wires before the blower goes in.
sorry you had a bad experience with them sean. can you send the links to the sleeves you bought please? the ones i know of are double walled and mil-spec'ed. not every product is right for everyone, but if its something i rep for, i need to know any malfunctions as we have big name customers and any failures on our parts ( not saying thunder or performance uses our customers) could be catastrophic. i.e aircraft, military craft, etc.
The other sleeves are used were the Taylor Firesleeves. I just found it interesting that the sleeve did not burn, but the wire inside was melted and cracked. There I was trying to find my mis-fire. On a dark night, popped the hood and saw the blue spark off the header. I would've never known, sincie I figured they were protected inside the sleeve. I have since routed them even further from the header. Shame on me I guess.
Me neither. I was also reffering to the resistance not the extra .5 mm that made them better. As previously stated, the Taylors will still work just fine I am sure. I doubt anyone could seriously tell a difference in performance between the two.
I have used the MSD 8.5's for about 6 yrs and I think there great. The first set I cooked. So the next set I used DEI wire insulators and that set, which is currently on my car, is about 3 yrs old.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
grabbem88
Mar 18, 2015 01:25 PM
