Whats everyone using for plug wires?
Old May 17, 2006 | 12:34 PM
  #16
Sean94Z's Avatar
Re: Whats everyone using for plug wires?
Originally Posted by myslowcamaro
i know someone that sells spark plug wire sleeves. good up to 1200 degrees. many colors pm if interested. they have heat wrap too
I've had 2 different sets of sleeves on my car. One from Perfomrnace Distributors and one that I got from Thunder .. Both sets allowed wires to burn INSIDE the sleeves..
They are definetly not the be all and end all of burnt wires..
Old May 17, 2006 | 01:03 PM
  #17
myslowcamaro's Avatar
sorry you had a bad experience with them sean. can you send the links to the sleeves you bought please? the ones i know of are double walled and mil-spec'ed. not every product is right for everyone, but if its something i rep for, i need to know any malfunctions as we have big name customers and any failures on our parts ( not saying thunder or performance uses our customers) could be catastrophic. i.e aircraft, military craft, etc.
Old May 18, 2006 | 03:38 PM
  #18
FastLt1's Avatar
What was wrong with the MSD 8.5s? The Taylors are only 8mm.
Originally Posted by CALL911
Just curious as to of the type/brand of plug wires people are using with their forced induction cars? I currently have the MSD 8.5 mm wires, but they are a little worn, and was considering changing the wires before the blower goes in.
Old May 18, 2006 | 03:46 PM
  #19
Sean94Z's Avatar
http://www.performancedistributors.com/livewire.htm .
The other sleeves are used were the Taylor Firesleeves. I just found it interesting that the sleeve did not burn, but the wire inside was melted and cracked. There I was trying to find my mis-fire. On a dark night, popped the hood and saw the blue spark off the header. I would've never known, sincie I figured they were protected inside the sleeve. I have since routed them even further from the header. Shame on me I guess.
Old May 19, 2006 | 11:18 AM
  #20
CALL911's Avatar
I couldn't find an OTVC MSD kit anywhere. Plus just for the regular MSD's it was almost $90, and for the Taylor OTVC it was $100. I would argue that the MSD's are probably a better wire, however I have had Taylors before and they will work just fine as well. Nothing was really wrong with my MSD wires, other than they were a little worn, and I wanted a new set to go over the valve covers. I would sell them, but I just ended up using a wire after one of my wires from my other f-body got fried, and had to use one of my MSD's that were not being used at the time.
Old May 19, 2006 | 11:35 AM
  #21
DarkHorse's Avatar
Just because the MSD's are 8.5mm compared to the Taylors @ 8mm doesn't mean that they are a better wire.
Old May 19, 2006 | 12:39 PM
  #22
Flip94ta's Avatar
I think the MSD's are the better wire because they have less resistance.
Do they make a cut to fit kit so you can go OVC with them?
Old May 19, 2006 | 12:41 PM
  #23
DarkHorse's Avatar
Not that i've seen
Old May 19, 2006 | 01:14 PM
  #24
CALL911's Avatar
Me neither. I was also reffering to the resistance not the extra .5 mm that made them better. As previously stated, the Taylors will still work just fine I am sure. I doubt anyone could seriously tell a difference in performance between the two.
Old May 19, 2006 | 08:19 PM
  #25
faSStcars's Avatar
I have used the MSD 8.5's for about 6 yrs and I think there great. The first set I cooked. So the next set I used DEI wire insulators and that set, which is currently on my car, is about 3 yrs old.
Old May 21, 2006 | 12:42 AM
  #26
93Phoenix's Avatar
Originally Posted by leadfoot94
Accel Extreme 9000s
123
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
