Turbo Build
Old Feb 10, 2008 | 07:58 PM
  #61
c0rey's Avatar
3.45 will net me 100 more RPM at 60 with slicks than a 3.23 with 275/40
Old Feb 19, 2008 | 01:53 PM
  #62
reamo04's Avatar
jw, cause i want to mount my turbo in the exact spot as yours, did you have to move the center section or anything?
Old Apr 23, 2008 | 07:28 PM
  #63
c0rey's Avatar
Originally Posted by reamo04
you can also use speed pro powerforged pistons part #TRW-L2441F30
those are about 400. Their heavy, but bullet proof basically
Any Suggestions on rings for these? Do they come with new pins?
Old Apr 23, 2008 | 09:36 PM
  #64
1982z28with18s's Avatar
Originally Posted by Tricked-Out-Toy
Probably a 31's. Those 3.45's will be great on the highway but you'll be wishing for more at the track.
With a turbo car you don't need a lot of gear. Hell with a n/a car and good converter you don't need a lot of gear. If my rear end would hold up, I think I can go mid/low 1.4x 60fts on these 3.23 gears and 26" tires. First try launching it(no 2 step or ebrake) and leaving IN VACUUM, I went 1.59 60ft bogging.(meaning I can leave in boost and not bog) Last year with 3.42's and a 28" tire it would go 1.56-1.58 60ft's leaving without the 2 step.
FYI, on the 2 step I can build 7lbs of boost instead of leaving in vacuum or at 1lb of boost at most, BIG difference.
Old Apr 23, 2008 | 09:39 PM
  #65
c0rey's Avatar
must get 2 step!
Old Apr 30, 2008 | 10:42 AM
  #66
DTI 00''s Avatar
lookin good man
Old Apr 30, 2008 | 10:55 AM
  #67
z28draco's Avatar
if you dont mind me asking, where is your 2 step set at ? thats a pretty good improvement in 60' and prolly a hella improvement in et
Old May 1, 2008 | 05:23 AM
  #68
Two step is set at 3300 right now, I haven't launched with the 2 step at the track though. Car goes 1.5's without the 2 step and last year went 1.5's without the 2 step and that was even on a narrow et street.
Old Jun 19, 2008 | 12:06 PM
  #69
95TALT1's Avatar
Hey c0rey do you seem to have any valve train noise with that 224/236 cam. I have a supercharger lt1 with that same cam and it seems to make a pretty good racket.
Thanks,
Waylon
Old Jun 19, 2008 | 08:28 PM
  #70
c0rey's Avatar
Ya the valve train was pretty noisy
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
reww86
Aug 29, 2015 06:04 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
