Turbo Build
Old Jan 6, 2008 | 07:15 PM
  #46
c0rey's Avatar
Well I have to yank the engine back out to redo the pan fitting. Im thinking I would like to throw some dished pistons in it.
With stock heads, gasket and everything what would be my esitmated ratio with these?
http://store.summitracing.com/partde...0&autoview=sku
The crank and rods were went through when the company did the factory rebuild. I just want to add the pistons. Will a balance be needed?
Old Jan 6, 2008 | 07:23 PM
  #47
reamo04's Avatar
c0rey, the problem with those, is it will not give you a low enough ratio, and they are hyper eutectic.
Drop a LITTLE bit more money (49.95/piston) on some speed pro power-forged
I'm assuming you have a 350, not a 355, or anything like that?
for a 350 - http://store.summitracing.com/partde...F&autoview=sku
that will put you around 8.7:1 compression
Old Jan 6, 2008 | 07:57 PM
  #48
Tricked-Out-Toy's Avatar
So whats too low of compression? If I wanted to order pistons now while the engine is still in the car and I dont know if my chambers have been opened up or my deck height, could I just figure the chambers are wost case, Stock and a zero deck, and order pistons in the 8.5 range? then when the engines apart and I find out the deck isnt zero or the chambers ahve been opened up its just icing on the cake and I end up with a CR of <8.5?
Old Jan 6, 2008 | 09:30 PM
  #49
c0rey's Avatar
Nevermind just going to drop the k-member down a bit.
Old Jan 6, 2008 | 11:21 PM
  #50
LT1-TA's Avatar
I would try for 8.5-8.7/1 range. Nine to one seems to be a a real solid number.
I am aiming for 8.7/1 with a 383 when the time comes. If i don't move to the c5 world before then (car could go up for sale once its running solid. Depends on offers)
Old Jan 8, 2008 | 09:08 PM
  #51
c0rey's Avatar
Wow that was fun used a different pan and redid the oil return that was leaking. Swapped pans with the engine in the car.
Things left
Put header gaskets on (remflex)
Put Bumper on
Get the right clamps for the Cold side(silicon stops fault!)
ReInstall everything and try it again! Maybe some better vids!
Old Jan 9, 2008 | 08:14 AM
  #52
jsetzer's Avatar
Things left
Put Bumper on
Never had an issue with them.... did you order clamps for your couplers or clamps for the pipe size??
Old Jan 9, 2008 | 10:06 AM
  #53
c0rey's Avatar
He just sent me the wrong one for the tb.
Old Jan 29, 2008 | 07:21 AM
  #54
c0rey's Avatar
With just switching the pistons out from the stock to the big dished ones will a rebalance be neccessary?
Old Jan 29, 2008 | 08:05 AM
  #55
jsetzer's Avatar
Stock as in stock gm ones? I would
I did not rebalance last time - but I kept the same rods and crank and went from flat top srps to dished ones.
Weight difference was within about 5 grams on each so I left it alone.
Old Jan 30, 2008 | 12:16 PM
  #56
CustomSSI's Avatar
Agreed man on the balancing.. weigh them and see what they all weigh and compared to the stock ones..
Old Feb 10, 2008 | 07:12 PM
  #57
c0rey's Avatar
Went to austin and picked up some new parts this weekend. Its a 9inch, aluminum driveshaft and slicks 27x11 Hoosier QTP Like new and like new fronts.
Here are a couple funny pics of a truck shop in oklahoma.
http://starcityriders.com/blazin/Mis...es/wheelie.jpg
http://starcityriders.com/blazin/Mis...ures/Woops.jpg
Old Feb 10, 2008 | 07:14 PM
  #58
2000GTP's Avatar
Pretty funny pics. Nice haul of performance goodies you got there. What kind of rear is that?
Old Feb 10, 2008 | 07:24 PM
  #59
c0rey's Avatar
Ford 9" 4.56 gears getting pulled out tommorrow for 3.45. Has auburn limited. Not sure on spline guy couldnt remember.
Old Feb 10, 2008 | 07:49 PM
  #60
Probably a 31's. Those 3.45's will be great on the highway but you'll be wishing for more at the track.
