Turbo Build
Old Dec 26, 2007 | 12:02 PM
  #16
RealQuick's Avatar
Remember, you can rotate the center section of the turbo approximately45 degrees to pick up some height on the outlet side. You will want a 45 degree fitting to straighten the line back out. Your oil inlet will aim toward the headlight.
Old Dec 26, 2007 | 02:18 PM
  #17
97s10ondubs's Avatar
where do you guys get your oil feed from?
Old Dec 26, 2007 | 02:49 PM
  #18
1982z28with18s's Avatar
pressure port right above the oil filter
Old Dec 26, 2007 | 10:26 PM
  #19
c0rey's Avatar
Couple more new pics.
Got the feed line done.
Taking the intake pipe to get tig tommarrow.
Paint is next so dont mind my crappy paint and gay front plate law.
Front bumper is just sitting on there aswell as the headlights.
Old Dec 27, 2007 | 07:43 AM
  #20
Sorry to hijack again, what size fitting did you use to tap into it?
Old Dec 27, 2007 | 07:52 AM
  #21
I want to say it was 1/8" npt, but I could be wrong. I had a fitting already laying around so I didn't go buy one so I'm not positive what size it is.
Old Dec 27, 2007 | 09:17 AM
  #22
RealQuick's Avatar
Corey, where did you end up placing the wastegate?
Old Dec 27, 2007 | 09:58 AM
  #23
c0rey's Avatar
Wastegate is placed in the same spot that you put yours on the logs on the cross over section.
If i remember correctly, the aux port on the block (above the filter) is 1/4" NPT.
Used a tial 5.83lb spring so we will see if that works.
Old Jan 2, 2008 | 08:48 AM
  #24
c0rey's Avatar
Okay next question for everyone what gasket should I use on the head flanges. I have 1 3/4 primarys with D port heads. I tried to use just rvt and that did not work. I got the car running and took it for a spin . But gonna tear it back apart due to the head flanges leaking. I was looking to use some circle port gaskets percy carbon xx but the gasket opening is 1.5 inch. Suggestions on d port or circle port. Def need a gasket cause the rvt isnt cutting it.
Old Jan 2, 2008 | 09:47 AM
  #25
RealQuick's Avatar
Orange RTV > gasket
When I pressure test my headers the gaskets sometimes leak, but then I use RTV and it seals up nice. Got to let it dry over night and the surfaces need to be clean for the RTV to seal. Not sure which gaskets you should use. Hopefully someone chimes in with a brand.
Old Jan 2, 2008 | 11:34 AM
  #26
c0rey's Avatar
Ya I used just rtv no gasket gonna try a gasket and that. Im thinking that the 1.5 in primary gaskets wont do much good at all. And the d port will seal the head perfect but not the flange.
Edit: Just found these I think the flanges would be more considered over rather than round gonna pic these up and try them.
Old Jan 2, 2008 | 11:56 AM
  #27
RealQuick's Avatar
Dont use rtv and a gasket.... just use one or the other.
Old Jan 3, 2008 | 01:10 AM
  #28
LT1-TA's Avatar
i used some graphite lookin gaskets and they seemed to hold the best... everything else has leaked pretty much instantly
Old Jan 3, 2008 | 08:09 AM
  #29
c0rey's Avatar
http://www.remflex.com/
Im going to give these a try they will refund my money up to 6 months after purchase date if im not 100% satisfied.
Teaser Video will make a good video once the snow melts off and i get it dialed in better.
http://starcityriders.com/blazin/newsetup1.mpg
Old Jan 3, 2008 | 12:11 PM
  #30
RealQuick's Avatar
sounds good!
