Turbo Build
Old Jan 3, 2008 | 01:08 PM
  #31
97s10ondubs's Avatar
Originally Posted by c0rey
http://www.remflex.com/
Im going to give these a try they will refund my money up to 6 months after purchase date if im not 100% satisfied.
Teaser Video will make a good video once the snow melts off and i get it dialed in better.
http://starcityriders.com/blazin/newsetup1.mpg
Did you cut the steel bumper support? I just put my 4" thick intercool on and was trying to get the bumper on and it's TIGHT, had to cut a lot off the bumper.
EDIT- nvm I see that's what everyone does, going to cut mine now
Old Jan 3, 2008 | 01:31 PM
  #32
reamo04's Avatar
haha
"nice soundin camaro"
"yea, we just built a turbo kit for it"
"oh ya did?"
i just noticed, i will be using the same turbo as you....how do you like it so far? Where does it spool up at? It sounds like its pretty instant, just wondering where thats at though? 2k? 3k?
Old Jan 3, 2008 | 03:26 PM
  #33
c0rey's Avatar
Not sure one the spool between 2-3. Ill have to play with it some more on the hi way and stuff.
Old Jan 3, 2008 | 03:45 PM
  #34
reamo04's Avatar
alright.
We basically have the same build, except im going to have realquick build mine (i dont haev a welder lol), and im using the 218/230 cam instead of the 224/236
I ran a couple engine simulators, and the 224/236 has about 25HP more, but the 218/230 had about 20ft-lbs more
Old Jan 3, 2008 | 06:31 PM
  #35
96TurboTA's Avatar
Sounds good man.
Old Jan 3, 2008 | 07:22 PM
  #36
IROCThisZ28ForLife's Avatar
nice setup!!
can someone tell me the part number for the forged pistons i need for a 355 build??
i know they have to be a certain cut piston but i dont know the name...diamond cut?? not likely but its something like that...for a 94 lt1
Old Jan 3, 2008 | 07:26 PM
  #37
reamo04's Avatar
Originally Posted by IROCThisZ28ForLife
nice setup!!
for a 355, SRP -24cc dished pistons
part #SRP-139632
$546.95
Old Jan 3, 2008 | 07:36 PM
  #38
thanks for the quick response!!,
im seeing that the stock crank is a good choice as well for the build up as from what ive read through the older posts...so most likely the pistons and rods will be the forged parts, and ill use the stock crank...
I would have to go 30 over with those pistons correct? and this will attain the proper 9.5 to 1 compression over the stock 10.5 right?
Old Jan 3, 2008 | 07:37 PM
  #39
reamo04's Avatar
actually, it will be about 8.6:1 compression which is proper for a forced induction build
Old Jan 3, 2008 | 07:39 PM
  #40
reamo04's Avatar
you can also use speed pro powerforged pistons part #TRW-L2441F30
those are about 400. Their heavy, but bullet proof basically
Old Jan 3, 2008 | 07:40 PM
  #41
isnt 8.6 a little low? i know its great for a f.i. setup but for a race car, this is going to be a cruiser
shouldnt 9.5 or 9.0 for that matter be fit?
edit: which are better then? the speed pro? if so might as well get those,
wow actually they are cheaper...interesting
Old Jan 3, 2008 | 07:44 PM
  #42
reamo04's Avatar
are you going all motor, or FI, or what? send me a PM so were not hijacking coreys thread
Old Jan 4, 2008 | 03:53 PM
  #43
any updates corey?
anyone know where to get the smaller height wise, yet longer intercoolers? I cant see that one being much use if its 75% covered up, like its ont a 240 or a sc300 so cutting the front bumper would look stupid IMO
Old Jan 5, 2008 | 03:48 PM
  #44
LT1-TA's Avatar
No. A Race car you run more compression and a ton of boost and all the timing because you are playing with race gas and can push the motor much much harder.
If you are going a HUGE power setup and wanna make everything you can on pump, low compression is the only way to do it. A lot of guys go with in the 9's for their street cars, but the HUGE power street cars have under that.
Old Jan 5, 2008 | 05:40 PM
  #45
yeah. its a car to have fun with, not looking to be a 2J slayer or anything like that...(Not that I would mind but you know)...Seems though its going to be far off away unless I delete my A/c which I'd really, really rather not do...But If its what I have to do to do it I might just have to go that route
