Max HP on pump gas
Old Jun 21, 2004 | 08:44 AM
  #16
rskrause's Avatar
Moderator
Originally posted by The Highlander
OOOHHH... ok...
WHen i was pushing 10psi boost i was doing 26º I could have done more.. but... its how i liked it..
Lets hope and see how this setup turns out to be with brets cam
More timing is not always better, "could have" does not = "should have". Best way to determine optimum timing is on a dyno measuring hp, AF ratio, and EGT's.
Rich
Old Jun 21, 2004 | 09:01 AM
  #17
IDOXLR8's Avatar
Rich
I agree.
I have seen some instances were too much timing cause a drop in hp. Most people are under the impression that as long as you see no knock you can just keep turning up the timing until you encounter knock.
Old Jun 22, 2004 | 12:15 AM
  #18
Highlander's Avatar
Well.. that depends... it depends on the RPM range you are doing this. remember best power is achieved when the full explosion occurs at 15ºATDC IIRC...
I ran 26 with 10psi...
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
