LT1 POWR's turbo build
Old Aug 22, 2010 | 06:56 PM
  #16
RealQuick's Avatar
Didn't get a whole lot done today. I built a support bracket and the merge.
Old Sep 6, 2010 | 11:47 AM
  #17
RealQuick's Avatar
Old Dec 19, 2010 | 11:28 PM
  #18
RealQuick's Avatar
Re: LT1 POWR's turbo build
waiting on a couple items before it i done, but here is a look @ hotparts with camera phone.
Old Dec 20, 2010 | 12:08 AM
  #19
QWKzee93's Avatar
MAN that is one pretty setup I like the way the manifolds came out. Those are some pretty welds you have there sir!
Old Dec 20, 2010 | 08:26 AM
  #20
RealQuick's Avatar
Thank you. The welds are OK. I am not a professional, but I try my best to provide a well laid out kit for the LTx crowd.
Old Dec 20, 2010 | 10:20 AM
  #21
QWKzee93's Avatar
mission accomplished! I'm always following your builds, if the funds are ever freed up for me I will have a kit of yours. Keep up the good work.
Old Dec 20, 2010 | 10:37 AM
  #22
RealQuick's Avatar
Thanks for the kind words!
Old Dec 21, 2010 | 02:51 AM
  #23
MikeGyver's Avatar
Lookin good. What do you normally do for coating? Have you considered/tried a ceramic coating on the hotparts for long term corrosion resistance?
Old Dec 21, 2010 | 10:14 AM
  #24
RealQuick's Avatar
Mike,
It is up to the customer to get the kit coated if he wants. I just had my shop car kit coated ceramic coated black(made of mild steel).
Old Dec 21, 2010 | 12:34 PM
  #25
RealQuick's Avatar
Old Dec 21, 2010 | 10:37 PM
  #26
LT1 POWR's Avatar
Sure does look good. I'm having a local guy ceramic coat the tubing. Should I do all of it? Can you coat a turbo?
Old Dec 22, 2010 | 12:00 AM
  #27
97WS6SCharged's Avatar
Just don't coat the inside of the hot side before the turbo. You can coat the turbo housing if you want. Makes it look pretty.
Old Dec 22, 2010 | 08:12 AM
  #28
RealQuick's Avatar
I think that is more myth than anything...
All professional coaters will coat the inside, even if they know it is a turbo application.
My turbine housing and compressor housing are both ceramic coated... inside and out.
Old Dec 22, 2010 | 02:33 PM
  #29
flyinZ's Avatar
Everything looks great! If you could delete the ABS block, it may free up some space for that drivers' side tubing.
Old Dec 22, 2010 | 04:29 PM
  #30
fastcam91's Avatar
man looks like its gonna be even worse to change that opti with that set-up. Looks beautiful though NICE!!
