ATI new inlet tube
Old May 4, 2006 | 09:44 PM
  #61
Ponyhntr's Avatar
Re: ATI new inlet tube
Here's the pic of my inlet:
Old May 4, 2006 | 10:27 PM
  #62
Violat0rX's Avatar
is yours just mounted differently? Looks good
Old May 4, 2006 | 10:43 PM
  #63
Ponyhntr's Avatar
I don't think I understand your question... That is ATI's new inlet, and that's how it was intended to be mounted.
Old May 4, 2006 | 11:15 PM
  #64
Violat0rX's Avatar
oic, I don't have that black shield that's under your filter. Also, I don't have my 90 deg rubber elbow angled up like that...mine is just perpendicular to the ground, therefore my filter hangs really low. I didn't know it was supposed to be mounted like that, i just followed the diagram, but was going to adjust it a bit when I had the chance. I wanted to give the filter more ground clearance.
It looks good tho, any problems in the rain?
Old May 5, 2006 | 02:22 AM
  #65
Sparkz28ss's Avatar
hhmmmmm... $220...anyone seeing anymore boost then the old setup?
Old May 5, 2006 | 08:10 AM
  #66
Ponyhntr's Avatar
I don't drive my car in the rain anymore, but there's another guy in town that doesn't have a problem at all with it.
$220? Mine was $150 plus shipping. I don't see any more (or less) boost than the old setup. The reason ATI re-designed it was to make it fit better and get rid of the orange hose. They tried to make it flow as good a possible, but the priority was to make it fit. It flows about the same as the dryer hose.
Old May 5, 2006 | 09:25 AM
  #67
BADST95's Avatar
The opening probably won't be large enough for an F1, huh?
Old May 5, 2006 | 09:31 AM
  #68
Ponyhntr's Avatar
Technically the inlet will fit on an F1, as the F1 shares the same inlet/outlet sizes as the P1SC and D1SC, but it may hinder the flow a little bit on your high-boost setup. What style of inlet do you have on the car now??
Old May 5, 2006 | 09:40 AM
  #69
BADST95's Avatar
I have a custome fabricated metal intake tube that I had powdercoated black. It does restrict my set up a little bit... 6 psi to be exact. So I just pulled the intake tube off to see full boost.
Old May 5, 2006 | 09:45 AM
  #70
T/A KID's Avatar
This may seem dumb but, why not just put a Filter on the outlet instead of trying to have the air make all those turns????
Old May 5, 2006 | 09:55 AM
  #71
BADST95's Avatar
Thumbs up Re: ATI new inlet tube
A lot easier said than done as there isn't a lot of room. The header would be kind of close if a filer stuck out. I have been trying to find a short filter to install, but I haven't been successful. I just did a little more searching.
Something like this might work.
Old May 5, 2006 | 09:57 AM
  #72
Ponyhntr's Avatar
Yep, it probably won't help you much!
Old May 5, 2006 | 09:58 AM
  #73
Ponyhntr's Avatar
Yeah, but there isn't much filter area there, and it will probably hurt more than anything.
Old May 5, 2006 | 10:16 AM
  #74
BADST95's Avatar
I was thinking of just using that filter for driving on the street. Just to be on the side of caution. With a small filter like that, it is easy to get to, and can easily be removed... unlike my intake tube (that is somewhat of a restriction to begin with). Let's face it, there is no way that I want to see 22 psi on the street anyway.
Old May 5, 2006 | 10:45 AM
  #75
Ponyhntr's Avatar
I gotcha there!
