ATI new inlet tube
Old Apr 14, 2006 | 02:26 PM
  #31
greenz2895's Avatar
Re: ATI new inlet tube
i just got my new inlet tube installed.pics are coming.i had the old setup and when i changed the inlet tube the is no place for the bypass valve hose to go so i just let it blow out under the car is that ok.i also haave to put my mass air flow some wear.i was going to put it up top but my air temp is up there.i have the d1-sc twin intercooler set up.its the one from last year.
Old Apr 14, 2006 | 05:17 PM
  #32
Ultra_Dog's Avatar
I just had my recirculating hose pop off at the MAF end and the car completely discomboblulated. It's been pouring rain here in California since last year and trying to isolate this problem from the side of the road in drenching downpours does not lend itself to quality and proper trouble assessments. Of course, once it was reinserted into its little hole... , the car is now normal again.
I can't wait to move the MAF to the top of the engine. Why in the world did ATI design this system in a closed manner (behind the MAF) in the first place?
Old Apr 14, 2006 | 05:23 PM
  #33
Violat0rX's Avatar
I'll try and get pics of my install tomorrow. THe filter now sits under the car right up behind the driver side intercooler's black plastic air deflector. I hope it can get some decient air flow there. As for the two barbed nipples, I got a short vacume hose and connected them. As I said before, my maf is already in the stock location.
BTW, what is the bypass hose / valve thing that you guys are talking about?
Old Apr 15, 2006 | 09:13 AM
  #34
BMAN'S SCZ's Avatar
I just got the new setup as well. It looks alot better than the old design. When I called ATI they said the two barbs were for a 97+ car. For my 95 I use one for the opti and plug the other one. In the new manual they sent, they blow the bypass valve to the atmosphere with a filter on the end. Does anyone know where I can get this filter other than ATI? Thanks guys....John
Old Apr 15, 2006 | 12:39 PM
  #35
blown383's Avatar
I still haven't had a chance to call up ATI but what was the cost?
-B
Old Apr 15, 2006 | 12:48 PM
  #36
Violat0rX's Avatar
i think it was about $150 + shipping.
Old Apr 15, 2006 | 06:41 PM
  #37
Pullngz's Avatar
Can someone please take some installed pics and post them. Or email them to me N2gravity@aol.com
Mike
Old Apr 17, 2006 | 11:47 AM
  #38
wicked_95z's Avatar
They told me the new intake tube was $220
Old Apr 17, 2006 | 03:31 PM
  #39
xxsaint69x's Avatar
i just put it on my car, worked awsome. Ill post pics tomorow.
Marcin
Old Apr 17, 2006 | 03:33 PM
  #40
blown383's Avatar
Marcin
Please do... we've been waiting months for this! Also did you see any increase in psi?
-B
Old Apr 17, 2006 | 05:47 PM
  #41
Violat0rX's Avatar
Here are a few pictures I took on saturday.
http://community.webshots.com/album/549589179fUZDDj
I didn't notice too much of a difference when driving. I still yet to install my boost gauge, so I don't know if there was a difference in PSI. The tube fits great, but it was really hard getting pictures of the peice the connects directly to the blower.
Old Apr 17, 2006 | 06:17 PM
  #42
blown383's Avatar
Thanks for the pics! From the looks of it the filter is so low that it'll suck up water or get knocked off the tube if you run over something! Geez! There has to be a way to move that filter somwhere else safer.
I also noticed that you're using the stock intake elbow? Why is that?
-B
Old Apr 17, 2006 | 08:58 PM
  #43
xxsaint69x's Avatar
-B
you cant see mine at all, it sits under the plastic cover. Ill take pics tomorrow
Old Apr 17, 2006 | 10:18 PM
  #44
greenz2895's Avatar
Violat0rX what did you do with youre air temp senser.and guys i also got a bigger k&n filter from my setup and it sits up more in the fender of the ground.
Old Apr 17, 2006 | 10:37 PM
  #45
Violat0rX's Avatar
Yea the filter sits pretty low and will definately suck up some water if I go through a puddle, but I don't drive the car in the rain anymore. I purchased the kit used from someone online and it turns out i'm missing a few peices. I was missing the elbow from the throttle body so Mike from Rapid Motorsports reused the stock elbow. I'm thinking about replacing the stock elbow with the vortech or trickflow one.
Also, from what I understand there is a plastic guard that goes around it or something, I think xxsaint69xx is referring to it. I'd like to see what it looks like.
I'm thinking that I could always turn that 90 deg rubber elbow the other way so it hides the filter behind the main air dam...but I don't know how much safer it would be there.
What does the temp sensor look like? Is it the sensor that goes in the elbow by the throttle body?
I do regret buying the kit used...the money I saved was spent buying and overnighting the parts that were missing!
