pump seal
Quote:
I haven't done any transmission work in over a year so I'm pretty rusty. Originally Posted by pattracing212
pump seal
This is a big thread so I assume your reply is in regard to one of the latest questions:
by Drowned
Quote:
Cracked band drum?! How can this have happened...
or Cracked band drum?! How can this have happened...
by SCNGENNFTHGEN
Quote:
the other day, on my way to work, about half way there, when I noticed it had no 3rd, or 4th gear. I take off, and everything is ok at first. It goes in 1st gear like normal, then shifts to 2nd no problem. Then it goes from 2nd like its going to shift, and it feels like its shifted into nuetral! It also still has reverse.
I'm thinking a pump seal could possibly cause the overheated drum, but not without other noticable symptoms {depending on which seal you are refering to}, and I wouldn't think a pump seal would produce a "no 3rd, or 4th gear" symptom without affecting other hydraulic modes; {which also depend on pump pressure for proper operation}.the other day, on my way to work, about half way there, when I noticed it had no 3rd, or 4th gear. I take off, and everything is ok at first. It goes in 1st gear like normal, then shifts to 2nd no problem. Then it goes from 2nd like its going to shift, and it feels like its shifted into nuetral! It also still has reverse.
Can you explain in detail further?
Quote:
I worked at a shop for 7 years that worked very closely with ATSG, and Sonnax Ind. Many of the products Sonnax sells now were products I helped create. The very first "Super Hold" Sonnax 4th servo prototype was in one of my 4L60E's. The very first Sonnax servo check valve was used in one of my 700's. The owner of the shop is an extremely intelligent man, who I learned alot from. I don't just pull ideas or opinions out of the air. If I have a strong opinion about something, it's because I've tested it.
Hey Frank,Originally Posted by 12SCNDZ
Dave,I worked at a shop for 7 years that worked very closely with ATSG, and Sonnax Ind. Many of the products Sonnax sells now were products I helped create. The very first "Super Hold" Sonnax 4th servo prototype was in one of my 4L60E's. The very first Sonnax servo check valve was used in one of my 700's. The owner of the shop is an extremely intelligent man, who I learned alot from. I don't just pull ideas or opinions out of the air. If I have a strong opinion about something, it's because I've tested it.
Is it ED Lee possibly??
Quote:
Frank
CPT
The good ol' del trans days. Ed lee is a genius no doubt. He's currently helping me with a few converter things. One hell of a nice guy!!!Originally Posted by 12SCNDZ
Yes, it is as a matter of fact.
Frank
CPT
Quote:
I began my transmission career at Deltrans. I learned alot of very valuable information from my 7 years there. Deltrans and Ed both strive to be leaders in the transmission field. The shop is equpped with it's own full machine shop and converter shop. If a part we needed didn't exist, we made it. The machine shop allowed us to come up with some incredible ideas and products. The prototype of the Sonnax "dual piston" 4th servo was originally used in one of my 4L60E's. Yes, we had a few "teething" problems...LOL. We spent alot of time proving /disproving what other peoples parts were capable of. Originally Posted by blackplague
Ed is who taught me to think ahead of the crowd. He's never been comfortable with "following". There's no doubt that I'm where Im at today because of Ed Lee. Everything I learned during my time there has carried over into CPT.
Frank
CPT
Quote:
Originally Posted by apss
JUST BROKE 15 MINS AGO. put the thing in R too back out and nothing feels like a load when givin'gas.i am so pissed.Nuetral is drive.WTF.SOUND LIKE A SUN SHELL PROBLEM.Man i am so mad.
Um...Nope, not the sun shell. I'd bet you're forward clutches are fried so bad that they've "welded" themselves together. This effectively means that your forward clutches are locked on. This will cause no reverse and will cause it to move forward in neutral.
This is most commonly caused by a cracked forward piston.
Frank
CPT
Frank
CPT
MAN THANKS FOR THE INFOOriginally Posted by 12SCNDZ
Um...Nope, not the sun shell. I'd bet you're forward clutches are fried so bad that they've "welded" themselves together. This effectively means that your forward clutches are locked on. This will cause no reverse and will cause it to move forward in neutral.This is most commonly caused by a cracked forward piston.
Frank
CPT
.WHAT DO YOU THINK IS THE BEST ROUTE; BUY A REBUILD FOR $600,OR GET THIS ONE FIXED?
Where you go from here all depends on your plans for the car. Be careful about those budget rebuilds, though. Our base 4L60E rebuild starts at $700. The price goes up with each "level". Our $1400 "Pro Race" build will take whatever you want to throw at it, and is 9 second proven.Originally Posted by apss
Frank
CPT
pump seal
I'm not for sure.. But it wasn't pretty!!
Quote:
As promised here is what went wrong in my 4L60E . Can someoneOriginally Posted by AZ2ENVY
I will be postin up when frank gets my trans. tore down
tell me whats wrong in these pics
??? You can say i got screwed over by the people that had to build my 4L60E MANY times over and over cuz
they kept dicking me around
. So frank at CPT is setting it the way it is supposed to be with a Pro Race build
Frank at CPT FTW !!!
My Z28 is a 94 BTW .
