voltage dips at WOT
Old Jul 26, 2007 | 11:41 AM
Mortify's Avatar
voltage dips at WOT
I have noticed that at 1/2 to WOT my voltage dips right between 8 and 13 volts (im guessing thats 10.5 to 11V) .. this is with my stereo off and no lights except DRL... is there a way to keep the DRL off at all times unless manually selected?
Also what would cause my voltage to dip so much?
Old Jul 26, 2007 | 11:47 AM
rickjames343's Avatar
I had an underdrive pulley from BBK (crank pulley) and my volts were extremely low at idle. but with any amount of gas, it would go back to normal. I ended up taking the pulley off and the volts are fine.
Old Jul 26, 2007 | 11:49 AM
Mortify's Avatar
I dont have a underdrive pulley... my volts stay at around 12ish volts at idle, it only dips during harder driving..
Old Jul 26, 2007 | 12:01 PM
Sweetred95ta's Avatar
I haven't seen it in the programming software, but I know some cars shut the alternator off at WOT. I've never heard of that with LT1's though.
Old Jul 26, 2007 | 07:47 PM
Guest47904's Avatar
Guest
You can't go by the gage. First confirm across the battery that it's at 14 volts at idle. Then stop worrying about nothing. Unless you drive all the time at WOT.
Old Jul 26, 2007 | 08:08 PM
Mortify's Avatar
well its more like the voltage drains more the higher the RPMs go... also its not just the guage... the speedo flicks instead of being a smooth rise
Old Jul 27, 2007 | 01:36 AM
sleeperz28's Avatar
this is normal for these cars. Under a wot pass mine goes from 14.2 volts down to 12.9 chased it for a year couldnt get anywhere then heard others did the same with no luck. If you need voltage get the boost a pump
PopoFormula
Oct 12, 2015 04:19 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
