asp replacement crank pulley worth it ???
Old May 27, 2005 | 03:44 PM
red96z's Avatar
not the piggy back one but the replacement one. i had the piggy back one before and removed cause of charging issues ,but since the cam idle has moved up enough to compensate what do u think??
Old May 27, 2005 | 06:48 PM
80TA's Avatar
Re: asp replacement crank pulley worth it ???
I put one in my 96 recently. I have stock idle and didn't like the way it was sucking down at idle the lights were dimming and stock stereo ,no big power draws even. Today I put in overdrive alt pulley and much better. I would think with an idle of around 800 or 900 you would be fine . Likely will raise my idle later on. Then maybe take the overdrive alt pulley off.
Not sure what gain if any got but the asp is a very nice piece .And I had the add ons before but thought they made the engine rougher.
Old May 27, 2005 | 09:35 PM
red96z's Avatar
damn man thanks for the reply i just wonder if its worth it for my mods??? i have a higher idle do to my cam so charging is no worry btw what did u give for it ?? and where did u get it??
Old May 27, 2005 | 09:39 PM
madwolf's Avatar
I put one on my car along with an underdrive alt. pulley and although I didn't get a chance to drive it, my lights seem to be the same way as before. My car idles at 900 and I don't have A/C.
Old May 28, 2005 | 04:58 PM
red96z's Avatar
where did u guy it how much???
Old May 28, 2005 | 04:59 PM
madwolf's Avatar
Got the alt underdrive from one guy on the board and the crank replacement from another. I had to find the correct belt myself because the one that came with it didn't work on my setup. (too long)
Old May 29, 2005 | 08:47 AM
80TA's Avatar
I got my overdrive alt ,underdrive balancer off this board used but they are pretty rare and almost never in stock anywhere. Its a top quality piece and looks nice even it mabye it don't give any reduced et or higher mph.
I did 2800 vig and 30 pound injectors and the pulleys at same time so no idea how much it helped. Too many changes.
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
