trans coller install ideas
Old Oct 18, 2004 | 10:56 AM
camaroKid223's Avatar
im getting ready to install my b&m trans cooler today and came across an install that mounted the cooler horizontally under the bumper vs. vertical on the rad here is the pic do you think this will cool as well, maybe put a metal scoop under it to force air up into it. i liked it because it doesnt impede the airflow into the rad.
Old Oct 18, 2004 | 03:14 PM
Re: trans coller install ideas
I have my Perma Cool trans cooler mounted in that spot, but on the driver's side. But it has a 9" fan on top of it, to provide air flow. I don't think you will get much air flow without the fan.
http://cjcfo.fbody.com/members/injun.../DCP02963a.jpg
Old Oct 18, 2004 | 03:17 PM
madwolf's Avatar
I mounted my cooler (28K B&M) to my radiator. The next cooler I had was installed my Speed Inc and they mounted it right above the air dam (drilled holes in the metal piece) and drilled two holes in the dam for the hoses. Both worked just fine, but the 2nd one is easier to install/access. There was no change in engine running temperature in either case.
Old Oct 18, 2004 | 03:23 PM
hmmm...looks like its going on the rad then thanks.
p.s injuneer im in love with your car, madwolf im gonna be talking to you soon about a tune id like to have done.
97Z28Muscle
Feb 6, 2015 10:44 PM
maybe2fast
Feb 5, 2015 05:14 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
GigaMp3z
Feb 20, 2003 02:57 PM
