anyone gone from 3.23 to 3.42?
Old Oct 6, 2005 | 11:59 AM
Mr. Merk's Avatar
did you notice it much? what kind of rpm increase was there at hwy speeds?
gas mileage drop much?
Old Oct 6, 2005 | 03:20 PM
Re: anyone gone from 3.23 to 3.42?
Your RPM and your rear wheel torque will increase by 5.8%. Doesn't seem like a whole lot, but you should be able to feel it. Currently you should be about at about 2,075rpm at 70mph in O/D. The rpm will increase to 2,200.
Old Oct 6, 2005 | 03:50 PM
Mr. Merk's Avatar
which on a stock 3.4 auto would equal roughly a 9ft-lb increase in torque
Old Oct 6, 2005 | 04:52 PM
MustangEater82's Avatar
I did it on my 5-speed 3.4L I noticed the differnce by seat of pants and times...
worth it in my opinon.
Old Oct 6, 2005 | 08:36 PM
Mr. Merk's Avatar
any mileage decrease???
also at the crank it would be a 12ft-lb increase over stock
Old Oct 7, 2005 | 09:48 AM
Jameslt1TA's Avatar
I wouldnt bother with it . Too little of an increase for all the work and money involved.
Old Oct 7, 2005 | 10:50 AM
viperkiller's Avatar
i went from 3:23 to 3:73 to 3:42. didnt really notice much change on the first swap, but i never had an equal field to judge as i never got traction with the stock gears. but for the amount of highway driving i was doing the 3:73 turned more rpm's then i liked. so i went with 3:42. they do tons better on daily driving, but have not been to the track yet. as far as SOP testing i didnt notice much change in the 3:23 and 3:73, as i had spinning problem with both. but with the 3:42's they feel possibly a little bit slower off the line, but not really noticable. but the car is in the power range a little bit longer and actually feels a bit quicker in the mid range, like passing gear and such.
to sum all this up, if you dont mind running 2500 rpm at 70 and have sticky tires then 3:73 are cool, if you want a good middle of the road gear 3:42 are cool. you get a little more kick on the line and you can still run 75 or 80 without winding your car up to 3000+ rpm. i never really noticed milage differance in any of them. but then again with the cam i have if i go any higher gear i will get a ton of surge at hwy speeds.
Old Oct 8, 2005 | 02:26 AM
Mr. Merk's Avatar
with what we have planned it would be more work keeping 3.23s
i'd say 9ft-lbs to the ground is a significant increase, esp on a V6 car
colts0455
Jul 24, 2015 04:51 PM
vwb11356
Jul 22, 2015 06:51 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
blac94Z
Mar 2, 2015 06:03 PM
blue98SS
Jul 3, 2002 04:18 PM
