Using Camaro program in Corvette?
Old Sep 23, 2003 | 04:05 PM
chevysam's Avatar
Can a Camaro program be used in a Corvette PCM? The computer is being used for an engine swap so it's not being used for anything but engine control.
I remember reading you can't put a Corvette program into a Camaro, but can you do it the other way around?
Old Sep 23, 2003 | 05:32 PM
madwolf's Avatar
Yes you can, provided you don't use the central control module. (which you most likely won't on a swap)
BUT, the A/C won't work correctly. (if used)
Old Sep 23, 2003 | 05:54 PM
chevysam's Avatar
Thanks for the reply. That's exactly what I needed to know.
I don't have the central control module & I'm using the original A/C setup that came in the truck.
Moshbmx1
Jan 20, 2015 03:27 PM
Dec 23, 2014 07:52 AM
ChrisFrez
Dec 7, 2014 06:01 PM
CaRParts102
Dec 6, 2014 08:45 AM
thenewkid
Nov 27, 2014 09:41 AM
