First #'s with my 94 A4 stock Z...is something wrong?
Old Aug 2, 2002 | 11:49 PM
DarkHorse's Avatar
Post First #'s with my 94 A4 stock Z...is something wrong?
Well, like the subject says I think something may be wrong with the car. I'm seeing people posting #'s here that are great but I did not see near those numbers tonight with a stock car. So, I think something is wrong with the car or driver (both?). Take a look at the numbers and critique/flame/bash away so I can learn from this. At the end i'm going to note some of the things pointed out to me by a buddy who was with me and runs an 11 sec Z. Thanks:
1st run:
60ft:2.207 330ft:6.325 1/8 ET:9.711 1/8 MPH:72.71 1000' ET:12.566 1/4 ET:15.037@92.61
2nd run:
60ft:2.210 330ft:6.327 1/8ET:9.706 1/8MPH:72.93 1000'ET:12.543 1/4ET:14.997@93.17
3rd run:
60ft:2.314 330ft:6.483 1/8ET:9.891 1/8MPH:71.99 1000'ET:12.781 1/4ET:15.279@91.24
Found out that I had 30psi in fronts 21psi/right rear 30psi/left rear
87 octane gas(oops, I know now premium only)
Is something wrong or did the tires and gas cause some problems? Blast away
94 Z28 A4 GU5
Currently in the shop
TransGo Shift Kit
Old Aug 3, 2002 | 12:19 AM
Kreinmc's Avatar
Post
You might wanna look under the hood and make sure you weren't tricked into buying a v6. jp. unless you are at a seriously high altitude something is definately wrong with the car. Your mph indicates that you are missing alot of hp.
94 Formula-6spd, New Mods are cloyes double roller timing set, CSI WP, Opti conversion,PCMFORLESS tuning, Comp R lifters and cc306, Hurst Shifter, Hotchkis Control Arms and Panhard Rod, Moroso Cai, Msd Ignition, Flowmaster Exhaust, Mac Headers & y-pipe, offroad pipe, Crane 10308 spring kit, 1.6 Promagnum RR's
Dyno with headers and RR's!
297rwhp
328rwtq
13.2@112.65(stock heads, full weight, 92 degrees outside)
Old Aug 3, 2002 | 12:28 AM
DarkHorse's Avatar
Post
I doubt it's altitude, I'm in NE Ohio. I think something is wrong as well but the car doesn't surge or anything. I'm at a loss unless the tires and gas were holding the car back somehow. The low MPH worries me.
94 Z28 A4 GU5
TransGo Shift Kit
Old Aug 3, 2002 | 12:52 AM
rock1501's Avatar
Post
get it scanned,something is wrong for sure.When I was stock I traped 97 and I thought that was low.It could just be an O2 sensor or something
96z,A-4, k&n cai,373gears,mack headers,highflow cat,3inch cutout, flowmaster catback,crane 1.6rr`s,crane dual valvesprings,underdrive,LT4KM,hpp,tb bypass,3000 vigilante,transgo,et streets.suspention is totally stock
best time slip(BOLTON) 60 foot 1.704 1/8 mph 85.37 1/8 et.8.044 1/4 mph 105.89et 12.654
cc305 cam,pcmforless programming
best time with cam(corrected)12.29@110.21mph
Old Aug 3, 2002 | 01:03 AM
DarkHorse's Avatar
Post
Could the low octane gas mess with the knock module? And then cause the timing to be turned back or something? Also, my tires were awfully low. 20 psi in the right rear, was I "dragging" this tire around? Max psi on my Dunlop sp 5000 is 51. Pretty low.
Old Aug 3, 2002 | 01:20 AM
rock1501's Avatar
Post
its not the tire pressure.I run only 14 psi in my et streets and I only lose 1 mph in my traps from 30 psi in street tires.
but it definatly could be timing retard
Old Aug 3, 2002 | 03:25 AM
snksknr94's Avatar
Post
It could be many things. You need to get it checked out/scanned rather than have us throw out a bunch of guesses. I had a similar problem and it was my fuel pump, but you need to find out for sure.
Old Aug 3, 2002 | 04:16 AM
AL SS590 M6's Avatar
Moderator
Red face
That 87 octane for sure did you in. When the computer detects just so much knock it changes to a low octane timing table that kills off a bunch of horsepower.
Run a couple of tanks of good highest octane unleaded you can find thru it then take it back to the track.
I'd put the back tires at 25-27lbs for street radials and pump the fronts up to 40lbs.
Have fun.
Al
Blue Green Chameleon 2000 Formula Hardtop
A4, 3.42/Eaton HD posi TA cover, Raytec sleeve, ARP studs
Yank ST3500, TransGo, & cooler
FRA, Direct Flo/K&N, EGR bobbitt, HPP
!TB coolant, Just Me Thermo mod, ATI dampner
SLP resonator exhaust, ES tranny&torque arm mounts
Home Boxed LCAs/ES bushings, LCA relocators
Best 60' 1.753
Best 1/8 8.106 @ 86.45
Best 1/4 12.704 @ 106.68
Best Mph 109.72 with a tail wind
and her
Black '98 SS# 590 M6
T-tops, Leather, Loaded
Old Aug 3, 2002 | 07:52 AM
TedH's Avatar
Post
When was the last time a basic tuneup was done on the car. Simple stuff, plugs, wires, filters... The car should be in the upper 90's with stock exhaust manifolds. The low octane gas could certainly affect the car as well, but check the basic stuff too as the speed is waaaaay off. Your sixty foots are pretty bad too, but there has to be something more than a simple loss of traction that is slowing you down. A slipping tranny could also cause this type of problem...
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
Old Aug 3, 2002 | 10:33 AM
DarkHorse's Avatar
Post
Thanks for the help. The tuneup was just done 2 weeks ago. New opti, water pump, plugs, and wires. I just bought the car and the Opti was bad so I took it back to the dealership and they replaced the parts listed above. Time to get some gas and head back to the track.
94 Z28 A4 GU5
TransGo Shift Kit
Old Aug 3, 2002 | 10:17 PM
StreetStang37's Avatar
Post
There can be lot's of things or nothing at all wrong with your car. What was the MPH of other cars? Bad weather can make a big difference, there were some day when I was trapping 102-103's and my friends lightly modded LT1's were in the 93-95mph range and LS1's having a hard time breaking 100. Too many variables; heat, humidity, baro., elevation, wind.
the best way to really test it is race another auto Z28 and see where you stand, you can't really trust the track times. As for your times, they all match up from 60 to 1/8 to 1/4 and MPH's, so IF you are down on power it's throughout the power band. If anything your car pulls just pinch above normal in the topend (or your low end is slightly below normal, pick whichever) but both still in the normal range.
1993 Grabber Blue Mustang GT
"Bolt-On's" (no power adder(s)
13.007 @ 108.39 w/ 2.149 60'
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Ryabut98
Sep 3, 2002 11:45 PM
