PCMcomm revisited
Old Apr 14, 2004 | 08:41 PM
88RX7LT1's Avatar
PCMcomm revisited
PCMcomm reads the MAF sensor with something called MAF / gm? PLEAASSE, what is this. I need MAF v. kilopascals (kpa) to program my computer. Anybody have a conversion, suggestion or otherwise?? Thanks. Preston.
Old Apr 15, 2004 | 01:20 AM
turbo_Z's Avatar
Re: PCMcomm revisited
its reading the incoming air in grams/minute. I am not sure what mean by needing MAF v KPA.. there is no table in tunercat and LT1edit that im aware with those 2 tables in that sort of relationship.
Old Apr 15, 2004 | 04:48 AM
SMOKNZ's Avatar
HE is propbably talking about the MAP, but even then it's kpa vs. RPM for VE tables and timing, who knows
Old Apr 15, 2004 | 10:51 AM
88RX7LT1's Avatar
My bad; I meant MAF kpa so I can tune VE table maf v rpm.
Anyone know the conversion for grams/minute to kpa???
Old Apr 15, 2004 | 12:20 PM
R_Andersen's Avatar
The MAF sensor does not give you a vacuum reading. The MAP sensor gives that reading in KPa. The VE table look up is by MAP vs. RPM. The MAF readings have nothing to do with VE tables.
-Rob
Old Apr 15, 2004 | 12:41 PM
88RX7LT1's Avatar
-Rob
F**K, i'm an idiot. and the map figures from pcmcomm are in Kilopascals. Thank you all for pointing out the error of my ways.
One more dumb question; if I increase a VE table value, will it increase or decrease the BLM at the given range?
Old Apr 15, 2004 | 03:08 PM
96ZRDR's Avatar
PCComm reads LT1 too? Did not know....
Old Apr 15, 2004 | 04:37 PM
SMOKNZ's Avatar
It won't do jack unless your running in speed density mode. BEst way to adjust BLM's is to look at them. If they are high/low across the board then change your injector constant. If they are high/low in certain areas, look what area on the MAF (NOT MAP)table correspond to that amount of flow and change those values.
Bill
DirtyDaveW
23
Apr 12, 2006 04:13 PM
lt1ownsall
Apr 30, 2004 10:22 PM
88RX7LT1
Apr 11, 2004 04:00 PM
slimdawson
Dec 23, 2003 11:12 PM
slimdawson
Nov 28, 2002 02:20 PM
