voltage problems??
Old Jun 21, 2007 | 12:31 PM
touch109's Avatar
voltage problems??
I just recently installed and aftermarket amp with aftermarket speakers but kept my stock headunit.. when i turn the a/c and radio on while i'm driving i see the battery gauge dip down to the red area even though its right at the edge I was wondering is their something i can do to help it not get there
Old Jun 21, 2007 | 05:01 PM
fredmr39's Avatar
details on the amp/speakers would help -- are we talking over 1000 watts?
I would take readings other ways rather than rely on the gauge just to see what exactly you are at.
As far as helping -- could try upgrading the charging system wiring....works for some -- typically though the stock wiring is sufficient up to 1000 watts and should be able to handle at least what your alternator puts out. Other than that, H/O alternator. (your alternator could also just be going bad..)
Old Jun 21, 2007 | 05:59 PM
touch109's Avatar
the amp is a 4 channel 450 watt , and 2 100 watt speakers in the front, 2 100 watt woofers and 2 80 watt rear panel speakers
Old Jun 22, 2007 | 08:42 AM
valter's Avatar
Do you have same reading from battery gauge with amps/headunit on but at zero volume? Something tells me you have a drain in your system, possibly amp idle current is way too high.
Old Jun 22, 2007 | 05:03 PM
fredmr39's Avatar
can we have model numbers on everything? why are you running so much off that 4ch anyway? (if I read it correctly....)
blac94Z
Mar 20, 2015 09:58 PM
Scottyboy
Feb 11, 2015 10:28 PM
pete53
Dec 9, 2014 07:31 AM
JSK333
Sep 9, 2002 10:33 PM
slothgrant
Aug 22, 2002 03:01 PM
