Weight
So a 335i goes something like this:
L --- 180.3in
W -- 70.2
H -- 54.2
WB - 108.7
WT - 3571
300HP 300lbft
225/45R17 H tires
19/29mpg manual, 20/29mpg auto
$40,800
Camaro Concept
L --- 186.2in
W -- 79.6
H -- 53
WB - 110.5
WT - ???
400HP 400lbft
275/30R21 front, 305/30R22 rear
Fuel econ ???
Hopefully less than $40,000
I picked the 335i because it has the most power out of the regular 3 series. Honestly it is somewhat interesting when you look at the specs side by side. Camaro isn't terribly bigger than the 335i, although it would be noticeably longer and wider. If you look at the 328i though, it only weighs 3351... so the extra 70HP-100lbft comes at the price of about 200lbs. At any rate, the 3 series should have more fluff options that add a few pounds here and there compared to the Camaro, although the 3 series does have more sensibly sized wheels than the concept did. The production car will likely have lighter and more realistic wheels. But at any rate I think a Camaro sized similar to a 335i with an aluminum V8 could potentially come in between the 328i and 335i in weight... assuming some luxury weight is removed, and the weight saved with an NA motor counterbalances the extra weight for transmission and rear end reinforcement. The other thing that is clear is that it might be quite an accomplishment if the Camaro does come in at 3500lbs curbwt, but I don't see how it would be completely out of the question. We'll have to wait and see though.
L --- 180.3in
W -- 70.2
H -- 54.2
WB - 108.7
WT - 3571
300HP 300lbft
225/45R17 H tires
$40,800
Camaro Concept
L --- 186.2in
W -- 79.6
H -- 53
WB - 110.5
WT - ???
400HP 400lbft
Fuel econ ???
That being said, you are all lunatics comparing the 3 series (about $32k base) with the Camaro (about $24k base).
I love how people are saying the GM shortcut the Camaro and that is why it is going to have more weight than what they think it should have. So, since you all are experts, why don't you go talk to Rick or Bob and tell them where they messed up. I'm sure they would be willing to listen.
L --- 180.3in
W -- 70.2
H -- 54.2
WB - 108.7
WT - 3571
300HP 300lbft
225/45R17 H tires
$40,800
Camaro Concept
L --- 186.2in
W -- 79.6
H -- 53
WB - 110.5
WT - ???
400HP 400lbft
Fuel econ ???
L --- 180.3in
W -- 70.2
H -- 54.2
WB - 108.7
WT - 3571
300HP 300lbft
225/45R17 H tires
$40,800
Camaro Concept
L --- 186.2in
W -- 79.6
H -- 53
WB - 110.5
WT - ???
400HP 400lbft
Fuel econ ???
The BMW mentioned has a 3.3 liter in-line six that's smaller in displacement than a V6 Camaro, and is a car that's alot smaller in physical size. Add a V8, and then you have to upgrade everything else from transmission to differential to brakes. The other thing is that the BMW doesn't actually have alot of "fluff" items that you can't get in a Saturn. There's probally more "fluff" items available in a Grand Prix.
So the question still is what are we prepared to give up? Are we willing to give up a V8 engine to get weight off to that (for whatever reason) magical sub-3500 pounds?
The stripped down to the basics Z28 hardtop weighed in at just a hair below 3450 pounds. Add t-tops, leather, power windows, top sound system, and you're knocking on 3500 pounds. Add Automatic transmission, add 80 pounds (General Motor's own press release peg the V6 Camaro with no options at 3323 with the manual and 3380 with the automatic). That clearly puts the most 4th gens well into the mid-3500 lb catagory.
GM is going to have their hands full enough and lose more than enough sleep just taking off enough weight to counter the weight gains from all the added stuff we're getting in safety, durability, and performance goodies.
As for the "hopefully under 40 grand" comment, keep in mind a loaded to the gills Shelby GT500 lists for about 40K, and there's going to be a point where dealers are going to stop scalping and start charging list (as they did with the Supercharged Cobras). Also, Corvettes start just a few grand over 40.
A Camaro V8 costing 40 grand (unless, like the GT500, it's a limited production high powered car) is going to be a death sentence, regardless as to the weight.
I think you mean the Camaro V8 MUST come in under 26 grand in today's money.
Guy....did Scott hire you to run the GM's excuse department?
I bet the LSx weighs about the same as BMW's inline 6. As most of us know, the CID of an engine is a poor indicator of weight (example: 4.6L Modular vs 7.0L LS7).
Someone used the 335i weight as an example...if the V6 5th Gen was ~100 lbs heavier than that, it'll be near 3700 lbs. If the V8 is "a bit heavier" than the V6, then you're up around 3800 lbs.
Scratch that analogy.
The car is going to be big, and it is going to be heavy. We got it. Don't like it, but got it.
In my opinion, within means "+/-".
My crystal ball is telling me V6=3550 , Base V8=3650 loaded , Top V8=3650-3750 depending on whether or not they decide to go the Z06 route of weight savings.
In other bold predictions, this thread is a waste of bandwidth and we will all look back and laugh in about a year. All this thread proves is that passionate (read:hard-headed)people will argue about anything.
Let's talk about something different. I heard that they aren't making a Z28 due to lack of expected demand. The SS is the most popular package, so it will be the top dog
If you dont like the weight of the new V8 Camaro, just get a 3600 pound V6 and add a supercharger and intercooler..and woops, you are up another hundred pounds.
On Star standard, IRS standard, 5 star front and side crash rating with standard side curtain air bags. Chevy is GMs value leader and Scott has already stated that high cost, low weight materials will NOT be used in it. The new Camaro owners wont be bashing the 04-06 GTOs as heavy pigs. DONT WHINE, DEAL WITH IT! Hmm, where have I seen that before.
Which brings us to the fact the 335i and 328i both have SIX CYLINDER ENGINES and driveline components that are a bit lighter duty than the M3's. You pointed out the weight being 3351 in an 328i. A 3800 V6 Camaro weighs 3307 according to GM..... and that's with an iron block.
I am also aware of how much a Corvette costs and obviously do not think a Camaro belongs in the same price bracket.
Should GM build a 3-series competitor? Yes, I believe they should. Should such a competitor be called "Camaro"? Not in a million years. The Beemer is a small compact-sized sports coupe. The Camaro is not, and never has been. The 3-series, while a great handling and quick car, isn't wide enough, long enough, agressive enough, or... heavy enough to be considered a "Camaro”.
I too think the 3 series BMW is an awesome car; have for years…that said, it isn’t and could never be a Camaro or Firebird.
I can appreciate how well made a 3 series might be…I can appreciate it’s smooth, responsive engine, how sure-footed it feels in a corner…how it can seem to stay composed under most any circumstance; but it will never be a Camaro nor would I want the Camaro to try to emulate a 3 series.
OK, here where I stand on all this.
My idea of a new and near perfect Camaro would probably be very close to Charlie's. A car that resets the pony car for a new age. Small, lightweight, rear drive. I like the BMW 3 series size (+/- 180") and personally have no burning need to to have the most horsepower on the planet, and prefer handling and the "Wow Factor" when it comes to performance.
I'm honest enough to say that my ideal Camaro won't sell, and will probably anger most of the Camaro enthusiasts at this website. I have no barrier against a Z28 that is the size of a G35, weighs 3300 pounds, and had a 3.6 Direct Injection V6 instead of the latest 500 horsepower V8. I'm not against superchargers (as you may notice in my sig), so the idea of a blown V6 instead of a NA V8 in no means ruins my day. But to the public and enthusiast at large, I know I'm speaking the unspeakable. But at the same time, we'd have a lightweight car and something definitely tossable.
Seriously though, I don’t understand where you get the idea that a smaller tidier Camaro won’t sell, or worse, would actually anger Camaro enthusiasts? Is this based on fact, research data, or opinion? You referenced low sales of the 3-series and G35 in another post. These really are not good indicators of how well a Camaro will sell regardless of size. These cars are not targeted to the same market segment and they are only niche players within their own segment. Camaro and Mustang started out as smaller, lighter, sporty cars by definition. Moreover, there have been smaller, lighter versions of the Mustang that have sold very well (Fox body comes to mind).
I think if you took the current 5th gen styling theme and built it around a 3-series sized platform you would have a winner. You could still improve upon the seating position; the ease of entry into the vehicle; and improve upon the interior space as compared to the 4th gen. The base vehicle buyer would be happy with their hot looking sporty car that gets good gas mileage; and the enthusiast will be excited with their size appropriate, light weight (relatively), great handling pony car.
To get lighter weight we'd have to start giving up things. Pricing and volume are off the table and non-negotiable because the car MUST be offer more style and value over the competition and that includes having a low price. The car also MUST sell at a certain volume, or it doesn't get made.
Now, within those confines (and this challenge is for everyone) what are we prepared to give up to get that "lighter" Camaro?
Starting will a large, heavy platform is an anchor around the neck that you will never be able to swim away from!
One general comment: It seems there are some people that have been claiming for years on this board that the later generations of the Camaro “got off track” or “lost their way”. Some of these same people -now seem to be condoning the thought of a two ton Camaro. I personally can’t imagine being more lost or off track than building a two ton Camaro.
Size vs. Weight...i don't want a small car, its not like that.
If 4th gens are so huge, why is my car around my perferred weight? The 5th is 7 inches longer than the 4th, its small enough, no excuse for a major increase in weight and if you want a 4000 pound car, thats your problem
The longer the wheelbase, the more steel you need to keep the same rigidity.
GM realizes Ford got it right with the Mustang, which will sell 500,000 to 600,000 units before the new Camaro comes out in spring 09. GM wants a good looking sporty high volume 2 door V6 model, a V8 performance coupe, a convertible the next model year and a high performance model after that. Sound familar? It is step for step mirroring the Mustang, from the V6 right up to the Shelby GT500 coupe and convertible models. Everyone bit(hing about weight can go out and buy a Monster Miata or LS1 RX7 and STFU.
