First Look at the Gen V Small Block
Re: First Look at the Gen V Small Block
SSCamaro99_3 and Koz
Sorry my post didn't interest you. Maybe some of your posts don't interest me either, but it would be rude and counterproductive for me to make an issue of it in a public forum. As you can see, it just makes the conversation to continue in the direction you don't care for.
So apparently a new 4.3L DI V6 based on the gen V is on the way as the base motor in the fullsize trucks. It would also be a good match for the midsize trucks. Should be around 300hp and provide the kind of torque that many of the smaller displacement DI V6s are lacking these days.
Media Screw-up:
From 0:40 to 1:47 this "LT1" dyno video actually shows a TT V6. At 3:54 it clearly says 3.6L at the bottom of the test screen. lol
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2730& transactionid=1351623580-7610844202&posted_by=ImportedRoomate_www.camaroz28 .com&youtube_video_id=PhnwMuISBJY[/autostream]
Anybody know about computer tuning simplicity or difficulty? I've been hearing that the new engines will have ECU's with 128 bit encryption that will be hard to "crack" and expensive to tune? Is there any truth to this rumor? The lock I heard is very similar to what is in Chrysler's cars, i.e, the Challenger.
That would be.......interesting. Considering up to this point, cylinder deactivation is not available with a manual transmission. Presumably because the engine would be constantly shifting from 8 to 4 cylinders every time you let off to shift and from 4 to 8 every time you got back on the gas (just my guess).
https://www.camaroz28.com/forums/aut...9/#post6924656
Media Screw-up:
Has any manufacturer ever published the reason cylinder deactivation is not offered with a manual transmission?
If you could feel a obvious transition between the two, AFM would be a disaster.
Maybe they have massaged it and it will work with a manual but I sure hope it doesn't come off as anything other than completely smooth.
That intake really does look very low. Do you guys think the intake height is as short as it appears, or could the heads be taller than those of the Gen 3/4 engines? If it's significantly shorter overall, it could have some interesting possibilities for what vehicles it would fit into (both from GM and for swaps)
FryZss
Sep 3, 2002 03:52 PM
routesixtysixer
Jun 23, 2002 02:29 PM
