First Look at the Gen V Small Block
Re: First Look at the Gen V Small Block
-Geoff
Now that some better photos and information is out we'll start a new thread. There should be a lot new stuff to talk about.
https://www.camaroz28.com/forums/aut...4/#post6924170
The LT1 finally beats the LS1
Meet The LT1: The Corvette C7's new 6.2-liter small block V8 [UPDATE]
Supposed to get 26mpg highway in the Corvette.
Well... Rumor has it that GM was testing a 5.5l at some point. There were a 1,000 different reasons they ditched it over the 6.2l though.
Apparently those bumps are for managing crankcase ventilation, with the inclusion of DI, there is no fuel spray on the backside of the intake valve to keep it cool or washed down or whatever making deposit build up a real problem on the backside of the valve.
Actually, it's the last minute tuning and programming that gives the final horsepower. The reason it's estimated hp is that they haven't finished the final programming yet. They can work on this all the way up till the first model comes down the assembly line.... even afterwards (first production models are often held back in case any last minute changes happen, or product issues need resolved.
I think someone posted above that the preliminary hp ratings for the ZL1 and ZR1 motors were less than the final production numbers.
I looked at that and found that both engines had final ratings that were about 6% above the preliminary estimates.
Using that as a guide, we might be able to say that the new LT1 could put out 477 hp in it's final rating.
Furthermore, if that's the AFM automatic version, and we use the L99 vs. LS3 model from the Camaro, we can assume another 6% gain from the AFM version to the non-AFM version.
That would put the non-AFM version of the LT1 at 506 hp. Right at the LS7 numbers.
And I think someone said the torque on the LT1 looked like the same numbers from the LS7.
So maybe my estimates are not too far off.
