Question
Old Jan 24, 2003 | 08:42 PM
Z- UL8TER's Avatar
Question Question
Maybe someone can answer. I've seen 17 roh wheels called Z
rated i think . Any way i saw a set for sell and said was on a porsche. Will these fit on a camaro? 96 .
size it says 17x7.5 and 17x 9.5 off set 5mm and backspace 5.472
Old Jan 24, 2003 | 09:36 PM
catsnet's Avatar
I may be wrong but as far as I remember porsches have 6 bolts
Old Jan 24, 2003 | 09:44 PM
Ernster500's Avatar
Are you talking about these?
ROH ZS
ROH ZS 2
Old Jan 25, 2003 | 05:36 PM
Z- UL8TER's Avatar
Yeah those r the wheels thanks guys.
I thought they were on a porche. they r 5 lug
on ebay starting bid only 100 bucks
Old Jan 26, 2003 | 10:12 PM
First, you need the right bolt pattern.... 5 lugs on 4.75" circle.
Then you need the correct offset/backspace on the wheels, or they will stick out of the wheel wells, or hit the suspension components.
In general, there is no way you could put a 5mm offset wheel on a 4th Gen. For the width wheels you are looking at, you will need offsets in the 45-56mm range.
Find out more about the wheels, including bolt circle and the offset for each width you are considering, and we can tell you if they fit.
Just as a guideline, the stock 8" wheels have a 55m offset, yielding a backspace slightly over 6.5". The stock SS/WS6 9" wheels also have a 55mm offset, giving a backspace of slightly over 7.0".
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
