Question for all running the LTCC
Old Mar 9, 2004 | 11:01 AM
  #61
TurboBob's Avatar
Smile
And I drop by here once in a while too.....
Bob
Old Mar 9, 2004 | 04:20 PM
  #62
Brettinator's Avatar
Bob thanks we got it running with your instructions, believe you talked to my friend on the phone or email Sat, his car runs completely different than it was now. All of the high rpm problems are gone.
Old Apr 8, 2004 | 05:03 PM
  #63
sleeperz28's Avatar
I pulled my motor about 1 month ago to replace the rod bolts. At this time, I did injectors, then proceded toturn the boost up a little higher. When I did this I started having problems with the LTCC again. Im not sure what is the deal with this box. It almost seems like its ideal for low horsepower applications? I have all my input wires away as far as I can, from any coil or plug wire, and its pulling codes again. It misses a little in the upper rpm range. It sounds like a rev limiter.
I think when it comes down to it, if you want to do it right the first time, put a conventional distributor in the car and call it a day.
Old Apr 8, 2004 | 07:41 PM
  #64
arnie's Avatar
Maybe the newer (and improved with more juice) coils are needed here.
Old Apr 8, 2004 | 08:08 PM
  #65
TurboBob's Avatar
What is your plug gap set to?
Bob
Old Apr 9, 2004 | 12:17 PM
  #66
sleeperz28's Avatar
.030 I believe. Why will a blown out spark cause a 2 or 3 code?
Old Apr 10, 2004 | 04:35 AM
  #67
bunker's Avatar
You have to remember that the LTCC doesn't sense a bad coil or misfiring plug, if you're getting codes its either opti related or PCM either with fuel injectors or any other part of the ignition system.
Old Apr 10, 2004 | 09:11 AM
  #68
TurboBob's Avatar
You're right, it shouldn't unless you are having problems with the plug wires.
Drop me an email I have a question.
B
Old Apr 12, 2004 | 04:33 PM
  #69
sleeperz28's Avatar
B
Bob did you get my email last week? I just got the one you sent me.....you got mail!
Old Apr 27, 2004 | 03:04 PM
  #70
dreamer1q's Avatar
I just started to install mine this past weekend. Where do I wire the tach into the harness? I want to do it right the first time. So any suggetions would be more then welcome.
Old Apr 28, 2004 | 10:44 AM
  #71
KGRESOCK's Avatar
Q,
wire in the tach at the PCM.
I'll check my schematics and let you know which wire.
Kevin
Old Apr 28, 2004 | 11:58 AM
  #72
94formulabz's Avatar
OBD 1: White wire, red connector on PCM, pin #13
OBD 2 LT1: Same as OBDI PCM * AFAIK
98 LS1: Tach line is Pin 35 on the BLUE connector. Tach line is a white wire
99-00 LS1: Tach line is Pin 10 on the RED connector. Tach line is a white wire
-brent
Feffman
Oct 9, 2015 05:42 AM
mikey4play
Mar 15, 2015 11:45 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
nophix
Nov 30, 2014 10:26 PM
