Question for all running the LTCC
Old Sep 11, 2003 | 12:04 PM
  #46
TurboBob's Avatar
The red LED in the unit will blink a code number at you.
BTW, Brady's car had a blown ignition fuse. His LTCC was fine.
Bob
Old Sep 12, 2003 | 09:52 AM
  #47
sleeperz28's Avatar
Bob
Good to hear it was something simple, although thats probably the first thing I would have checked. Anyway Bob the box works awsome, have not had any problems with it since the beginning of summer. As soon as I figure out why my boost doesnt go higher then 17psi im going to see if I can make 1000rwhp. A guess right now the box/coils have supported 800+rwhp.
I would recommend this box to anyone. I may have a few in the area interested but it would not be till next spring as its getting cooler and the cars will be done in a few.
Old Sep 12, 2003 | 04:46 PM
  #48
arnie's Avatar
7-24-03
Originally posted by sleeperz28
I started re-routing wires today. But when i was finished I ended up in the same spot. I pulled a code 2 and 4 on the way to work then a code 3 on the way home. i would go in and replace the optical sensor but the car pulls no codes under normal driving conditions. However the car pops between shifts, some louder then others. It never did this when the ignition was working propar.
Starting to think i should have done it right the first time instead of buying a cheap substitute. If I cant get this thing to work by the end of August im just going to throw a crank trigger and cam sensor in the car. never had this much bad luck with just the optispark
7-25-03
The stock opti does not have enough energy to fire 600+hp I dont have a 6a laying around along with a coil. Why come on the forum whining about it? why does anyone post on this forum, to inform, and help others that may have similar problems down the road. Dont get me wrong bob is a great guy to work with, but as I said this post may help another down the road.
Brady thats what im thinking hall-effect with crank trigger if this does not work. the hall seems like a better idea then the drilling into the cam gear.
Old Sep 12, 2003 | 10:30 PM
  #49
Brady's Avatar
FWIW, it wasn't my ignition fuse, it was my injector fuse. I checked the ignition fuse immediately but didn't bother to check the injector fuse (1/2" apart)... That one goes into the "lessons learned file"..
Old Sep 13, 2003 | 02:38 AM
  #50
sleeperz28's Avatar
Damn brady I just started experiancing the same problem. I blew one bank twice in one month, then steped up to a 10 amp. Went for another run tonight and blew the other 7.5. I put a 10 amp in the other side and made several passes with no blown fuse. At first I thought one of my wires from my fast harness is grounded but when the other blew I was stardled. What did you do to fix your problem? Im wondering if it has something to do with my high injector duty cycle. Im pushing the hell out of these 72#ers, it spikes 110 in second then rides 92-96 in 3rd.
Arne
Old Sep 13, 2003 | 06:55 PM
  #51
Brady's Avatar
DUHHH...bigger fuse!
I'm maxed out on my 83# injectors.. I upped the rev limiter and popped a fuse.. I guess it was the straw that broke the camel's back.. I asked @ TB.com and Craig said it could happen.. My car has a single fuse, it was a 15A from the factory and I popped it. I put in a 20A and it's been good ever since.
Good luck
Old Sep 14, 2003 | 05:13 PM
  #52
sleeperz28's Avatar
Yeah I ended up putting 2 10amp fuses in and have not had a problem with it yet. My 72#ers are at 94% duty cycle, I cant turn the boost up any higher then 18psi until I get my hands on some 96#ers. Brady you got any numbers(dyno/track 1/4 mile) out of your car yet?
Old Mar 6, 2004 | 04:37 AM
  #53
Brettinator's Avatar
Bob I sent you a PM requesting the correct wiring diagram for 93's, but if you get this first fine, could you post here the correct procedure or wiring for a 93 in that they are not the same wiring as what's listed in your instructions.
Honestly I don't understand why both sets of diagrams would not be included in your kits if it's so easy to cause damage in your LTCC box. Simple solution or improved instructions/wiring diagram would perhaps solve at least some of the LTCC damage problems I've been reading thus far. Just a suggestion.
Old Mar 6, 2004 | 09:08 AM
  #54
TurboBob's Avatar
Yeah, the instuctions are thin.....I suck at tech writing.
Some friends have helped write a better manual, but it's not ready yet.
I sent you instructions for the 93 via email
B
Old Mar 7, 2004 | 01:25 PM
  #55
OneFlyn95z28's Avatar
Well it is looking like most of the Bugs are gone. still leaning this way. not going to be one of your Higher HP cars but looking for 600-700RWHP N/A and 900-1000 on the juice
Old Mar 8, 2004 | 01:31 AM
  #56
Metlegleo's Avatar
Been running my LTCC on the 93 for over a year.....on motor and spray...should be running on the blower by Tuesday afternoon....just buttoning everything back up now. I don't have my LTCC manual handy.......can I feed off of the white wire for my autometer shift light?
Old Mar 8, 2004 | 06:58 AM
  #57
arnie's Avatar
Originally posted by OneFlyn95z28
Well it is looking like most of the Bugs are gone....
My first unit, on a '94, has been on since 2002. No bugs per sa, but I'll agree, the instructions are basically generic in nature. But anyone attemmpting this, should be armed with the correct gm service manual, or a thorough working knowledge of their particular wiring harness. As a mechanic, you should understand, and be in agreement, with that statement.
Old Mar 8, 2004 | 08:10 AM
  #58
TurboBob's Avatar
If the autometer can run from a 5 volt signal, then it will work.
Bob
Old Mar 8, 2004 | 08:52 PM
  #59
Arnie.
I know of a few bugs that came up and followed them as Bob promtly fixed them As a mechanic you also under stand just because it worked flawlesly in one case does not mean it was with out flaws
EVERY person i have had contact with said Bob was the best at customer service.
Old Mar 8, 2004 | 09:29 PM
  #60
96ltz's Avatar
I emailed delteq and Bob Bailey last weekend with some questions. Bob answered in less than 2 hours.
Delteq still has not answered so I resent it tonight.
