Horsepower
Old Feb 4, 2008 | 06:17 PM
  #46
rskrause's Avatar
Moderator
David again makes a good point. Just because someone once did it, doesn't mean YOU can do it. Whatever IT is.
Rich
Old Feb 4, 2008 | 06:49 PM
  #47
mdacton's Avatar
Rich
you can do anything if you put your mind to it
Old Feb 4, 2008 | 07:04 PM
  #48
rskrause's Avatar
Moderator
Don't we all wish
Old Feb 4, 2008 | 07:19 PM
  #49
jerminator96's Avatar
you can do anything if you put your wallet to it
That's probably more like it.
Old Feb 5, 2008 | 08:35 AM
  #50
white97T/A's Avatar
a whole lot. I think they build them for the customer so each set would be different.
What does "G.B." in the description stand for? What is "a whole lot? $3K, $5K, $10K? If they build the heads for each customer it shouldn't be too hard for them to make an LT1 specific set...
Old Feb 5, 2008 | 09:13 AM
  #51
They're part of the Brodix "GB 2000" series heads, MBE just modified them (albeit extensively).
I don't know what they cost, but I'm pretty sure thats a $4000+ set of cylinder heads before MBE gets them.
Old Feb 5, 2008 | 02:56 PM
  #52
white97T/A's Avatar
I emailed MBE and found out what "expensive" is
Email from MBE:
"The GB2500 heads are $6,730 pr bare, ready to assemble. Assemblies with custom titanium valves, PSI 1249 springs (1.00 lift max), titanium locks, Ti-17 retainers (same material as nextel Cup & NHRA pro Stock uses) $9,450.
We would have to convert these for you. The cost of converting is about $400"
Old Feb 5, 2008 | 03:01 PM
  #53
rskrause's Avatar
Moderator
Like I said, $25,000 for the power producing parts of the project might just do it.
Rich
Old Feb 10, 2008 | 12:48 PM
  #54
interceptor's Avatar
Dyno results
Just got the results from Karl on the dyno session at "A top secret location somewhere down South" on the King ERE 383. This motor has a very similar head/cam/valvetrain combo as yours silver95. This motor was King ERE #13 if your interested in the bottom end specs.
AI 215cc TF setup with the ProSeries SR valve train (Jesel)
Cam specs .668 on a 104 ICL
Stock intake w/ 1300cfm monoblade
Motor made 520hp at 7000 with 470ft/lb (not sure at what rpm as Karl was calling it in on his cellphone on the trip back)
This was a very conservative tune with the bottom end set up for a decent hit of nitrous. With a little better breathing manifold probably would have pushed the power numbers up a little.
Old Feb 10, 2008 | 01:04 PM
  #55
silver95's Avatar
That sounds promising.
Old Feb 10, 2008 | 04:05 PM
  #56
Very promising....but still a long way away from the 600-700 rwhp you're looking for.
If you really want that you may want to consider a different platform or at the very least a different set of heads.
Old Feb 10, 2008 | 07:54 PM
  #57
rskrause's Avatar
Moderator
Here's a fully developed (by Reher-Morrison, no less) 412ci SBC drag race motor. It develops 675hp with a 14:1 CR. There are many significant differences between this and an LT1 and it is a race motor that needs high octane leaded race fuel. Just a little perspective.
http://www.rehermorrison.com/superSeries/412Start.htm
Rich
Old Feb 10, 2008 | 08:03 PM
  #58
mdacton's Avatar
^^ similar to what I built out of an LT1...but I have stock ported heads and Fuel injection.
IMHO it was a huge mistake and the engine is a POS......I will never mess with a small blcok again. Huge waste
Old Feb 10, 2008 | 10:15 PM
  #59
silver95's Avatar
I was looking for fwhp (flywheel horsepower) not rwhp. Anyways, I found out what injectors to go with and that was the whole reason for this post.
Old Feb 13, 2008 | 08:17 PM
  #60
SS MPSTR's Avatar
Good luck with it...food for thought - an AI 355 with a small SR cam and their 200cc heads just put down 500rwhp through an M6. This car/engine combination is pretty close to the 600fwhp number you're after.
