Cam install question?
Old Feb 10, 2004 | 06:19 AM
Viking's Avatar
I'm planning on installing my cam with 4-6 deg retarded ( to move the rpm band up a little) how will this effect cyl pressure? and what more will it effect?
Engine is a blown superram engine 415 cui..........
It already has a +5 deg advance in it so I'm installing it "straight" up..............
Cam Spec Card Inquiry
PART NO. 08-301-8
01 INTAKE MASTER 3314S
02 EXHAUST MASTER 3316S
03 ENGINE CS NR276HR-113
04 GRIND NUMBER CS NR276HR-113
05 HYDRAULIC Y/N YES
06 VALVE ADJUSTMENT HYD
07 MAX GROSS VALVE LIFT .502 .520
08 DUR @ .006 TAPPET LIFT 276 288
09 VALVE TIMING @ .006 OPEN CLOSE
10 INT 30 66
11 EXH 82 26
12 THESE SPECS ARE FOR CAM(S) INSTALLED @ 108.0 INTAKE CENTERLINE
14 DUR @.050 224 236
15 LOBE LIFT .3350 .3470
17 LOBE SEPARATI 113.0
18 ADVANCE 5
19 VALVE SPRINGS 986-16
Old Feb 10, 2004 | 03:36 PM
MaxRaceSoftware's Avatar
if you retard the camshaft ..you will definetly lower effective cylinder pressure at lower RPM range and lower cranking psi
224 dur @ .050" looks a little small for blower/cid engine size you have..so retarding cam might help you out depending on your gas octane and blower boost psi
it depends also on how much converter/stall and rear gear ratio you run (car weight)
trial and error
don't forget to check exhaust valve-to-piston clearance
making a retard move like that will loose approx .005+" per deg on exhaust per cam phase movement
Old Feb 10, 2004 | 11:38 PM
Viking's Avatar
I know its pretty small, must pass emission, its not a race car and I wont rev it beyond 5700rpm.
Car is a TA-89 stock weight and 2400 rpm stall and 3.27 rear..
thx/N.
Old Feb 11, 2004 | 05:52 PM
arnie's Avatar
Originally posted by Viking
....must pass emission, its not a race car and I wont rev it beyond 5700rpm.
Then why retard it?
Old Feb 11, 2004 | 05:53 PM
Viking's Avatar
looking to move up the peak power 500 rpm......
/N.
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
