cam
Old Nov 12, 2008 | 01:16 AM
thebeast93's Avatar
cam
how much does it cost to buy a cam and have it installed?
Old Nov 12, 2008 | 05:20 AM
Absolutely impossible for anyone to answer that question, without knowing the specific engine you are asking about. Tell us about the engine, and I'll move your post to the correct forum.
Old Nov 12, 2008 | 03:25 PM
marshall93z's Avatar
That's too advanced for this section!
Old Nov 16, 2008 | 11:30 AM
johnny6's Avatar
Old Nov 16, 2008 | 03:56 PM
rskrause's Avatar
Moderator
A shelf grind roller cam is ~$250. A new cam will need new springs which can cost anywhere from $100-500. Other parts such as retainers, rocker arms, etc. may be needed as will gaskets, etc. Labor will vary a lot depending on the make and model and year and labor rate. That's why there is no simple answer. A 4th, for example, is not easy to work on. A cam replacement is a full days work. So, multiply the labor rate in your area by 8-10 hours and add parts. In my area the only guy you would want to do it is ~$90/h. So, a ballpark for a stock LT1 including a set of roller rockers would be close to $2,000.
Rich
Old Nov 16, 2008 | 04:17 PM
Klypto's Avatar
1000-2000k you can prob get it done for 1200-1500 somewhere and be fine. depends on if youll need the rockers
Old Nov 17, 2008 | 05:03 PM
sn8ke eatr's Avatar
id guess about 1500 plus parts..
unless your totally useless when it comes to cars, do some research and do it yourself
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
