Starter Circuit Voltage Problems
Old Dec 5, 2008 | 03:28 PM
redneckgames's Avatar
Im having some problems with my 94 Trans Am. auto
Long story short, the wire giving the voltage signal to engage the solenoid at the starter is getting 8 volts.
Battery cables are clean and tight. Battery checks at 12.4 volts. At the ignition switch there is 12.4 volts going in, 8 volts coming out.
So I replaced the ignition switch. Same thing with a new switch. I unhook the wire at the starter solenoid, check it unhooked and it has 12.4 volts. Go back to the ignition switch and there is 12.4 volts coming out of it. Hook the wire back to the starter, check again and 8 volts.
If you jump the starter at the starter, it will crank just fine.
What is happing? Solenoid bad?
Old Dec 6, 2008 | 12:17 PM
Not really "Advance Tech".... let's try this in "General 1967-2002 F-Body Tech".
Old Dec 6, 2008 | 02:14 PM
sorry being pretty advanced to me.
AlaskaZ28
Apr 17, 2015 08:54 AM
blac94Z
Mar 20, 2015 09:58 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Injuneer
Dec 15, 2014 09:36 AM
slothgrant
Aug 22, 2002 03:01 PM
