295/50/16
Old Oct 11, 2008 | 02:16 PM
TJ Chapman's Avatar
295/50/16
im thinking not but wanna double check: will a set of M/T radials this big fit stock wheels? on a stock suspension? on a 99 Z?
Old Oct 12, 2008 | 02:54 PM
I looked at the M/T website, and did not see that size shown on either of the ET Street Radial size charts. But the "links" for the two different tread patterns for the ET Street Radials both go to the same size chart. They used to go to two different sets of sizes. I did find that size with a "search", and it appears to be the "sport compact" tread pattern, not the tread pattern used on the really sticky drag radials that are often referred to as the "world's fastest".
A 295/50-15 would be a 26.6" tire, so the diameter would not be a problem. But M/T recommends that the wheel width be no more than one inch narrower than the tread width, and their 295 tires typically have a tread width close to 11", meaning you would need a 9.5 - 10.0" width for them to fit correctly. Stock wheels are only 8.0" wide.
Old Oct 13, 2008 | 05:13 PM
TJ Chapman's Avatar
yeah i kinda figured but i did find this size on summit im almost positive it was the et streets but maybe i was wrong. im sticking to 255s in some drag radial make
Andrew R
Wheels and Tires
9
Dec 26, 2007 01:50 PM
Blueblotch
Apr 21, 2006 04:58 PM
Fat_Boy
Wheels and Tires
Sep 22, 2005 09:34 PM
GreenZLT1
Wheels and Tires
Mar 23, 2005 07:20 AM
LS1 PWR
Wheels and Tires
Oct 20, 2004 07:00 AM
