will 225 35 18 fit on a 18x8 rim????
Old May 9, 2004 | 12:38 PM
TexasTechTA's Avatar
I know it is kind of a small tire but i am broke and am about to have a blowout on my front tires and need new ones. a guy here has 2 new for 50bux. will that look okay on the fronts? the car is lowered to so it will look better let me know asap thanks
Old May 9, 2004 | 08:08 PM
Z Power's Avatar
they will fit, but i would look for a bigger tire or at least some bigger sidewalls, potholes will be terrible for that size
Old May 9, 2004 | 10:11 PM
yea I knwo but I just need them for a little until i cna get new ones
Old May 11, 2004 | 02:11 PM
blind527's Avatar
what would be your point in wasting that money??? save it until you get the real deal.
Old May 11, 2004 | 03:47 PM
Most manufacturers recommend a wheel width of 7.5 - 9.0" on that size tire, so its OK with regard to "fitting" on the 8" wheel.
Where you may run into a problem is the fact that it is only 24.2" diameter, about 1.5" smaller than the stock tires. If you put them in the front, you are losing about 3/4" of ground clearance. If you put them in the rear you lose the ground clearance and your speedo will be reading about 6% higher than actual speed, and adding 60 extra miles to your odometer, for every 1000 miles you drive. The gap between the tire and the fender will grow by 3/4" as well.... might look like you are driving on a space-saver spare.
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
