Z06 Rims Wont Fit
Z06 Rims Wont Fit
Hello I called belle tire today and they told me that the corvette z06 rims 18x10.5 will not fit in the rear they will rub when turning. Did anybody ever put 17x9.5 and 18x10.5 on there camaro with no problems - Mike
Here's the deal on this...
REAL Corvette Z06 wheels with the Corvette offset in size 18 x 10.5 WILL NOT FIT on an f-car WITHOUT the use of spacers (not recommended) and/or hammering the inner fenderwell where they rub and/or rolling the fender lip.
Aftermarket replica Corvette wheels made in the SAME offset will naturally rub as well.
Aftermarket replica Corvette wheels made in the F-BODY offset will naturally do fine.
OEM dimensions are:
17x9.5 - 54mm offset
18x10.5 - 58mm offset
Its the 58mm offset that kills you on the 10.5" wide wheel, because that corresponds to an 8.00" backspace, and that puts the tire into the inner fender in the back. The 17x9.5's should fit with no problems at all.
4mm is only .157", so I would think that if you switched to an aftermarket brake rotor,Pronto (the cheap ones), the added thickness would make up for the offset. You may need longer studs though.
Botch
Botch
Originally posted by 1stls1
With the Z06 rims at 17/9.5 w/ 285/40 tires all around, would I have a problem lowering the car w/ springs?
Originally posted by bigdreamZ
Paul what offset and backspacing are you running? I asked you in another thread and also emailed you but never got a response...
and
56mm with 7.905" backspace (I think these are on the back)
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
