Question about offsets
Old Aug 6, 2004 | 11:10 AM
RealQuick's Avatar
Are the offsets built into the rim or are they like spacers? Just wondering because i am looking for ZR1 17x11 rims for the rear and 17.9.5 for the front and i wonder what the offsets are supposed to be. If I find a set that lists different offsets then what I need does that mean I cant use those rims or are there ways around it?
Old Aug 6, 2004 | 12:47 PM
Re: Question about offsets
Offset is "built into" the wheel when it is manufactured. It can not be changed. For the ZR1's, you need:
17x9.5 56mm offset
17x11 50mm offset.
The only other offsets you see would be:
17x9.5" 38mm offset
17x11" 36.5mm
Those wheels would be positioned a little too far toward the outside of the fender, but are preferred by some people.... just a matter of how much they stick out.
If the offset is too small, there is nothing you can do about it. You can not add a spacer. If the offset is too large, you could add a spacer to compensate, but that is not always a good idea.
Another possibility is the high $$$$ wheels like Fikse or HRE. These are 3-piece wheels, and you can alter offset by combining different selections of front and back "halves" of the wheel. Think in terms of $500-900 per wheel.
Old Aug 6, 2004 | 12:58 PM
RealQuick's Avatar
As always, fred is a wealth of knowledge! Thanks.
HectorM52
Jul 30, 2017 11:46 AM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
redzed
Sep 4, 2002 06:22 PM
