Need info on First Gen Wheels ...
Old Aug 4, 2004 | 02:16 PM
JT69SS's Avatar
Hello everyone,
I am considering putting new wheels/tires on my '69 SS. Does anyone know if the following will work? I've seen a few posts on the net about others using this kind of setup ... but want to be sure I don't need to make any modifications before I make the purchases.
275/50/15's on 15x8.5 Torq Thrust D's in rear
225/60/15's on 15x7 Torq Thrust D's in front
Anyone running a similar setup? Also, can anyone recommend the best source for Torq Thrust D's. Many Thanks for any info.
~JT
Old Aug 4, 2004 | 11:19 PM
NorthernSS's Avatar
Re: Need info on First Gen Wheels ...
http://web.camaross.com/forums/showthread.php?t=276871
Check the sizes I posted in this post. These were what Chevy High Performance found to be the biggest that you could go without fender mods. Is this the info you needed??
Old Aug 5, 2004 | 10:32 AM
JT69SS's Avatar
Judging by the diameter and tread width of the 16's in that article my 15's should be fine. Thanks very much for the info.
~JT
Old Aug 5, 2004 | 11:40 PM
NorthernSS's Avatar
No problem buddy
Old Aug 6, 2004 | 02:53 PM
Ls1smlblck's Avatar
That should fit but you need to fit out the back space........ with a 7 " in the front you'll need at least 3.75" and with a 8.5" rear you'll 4.50-5" of BS to keep from rubbing either on turns or bumps.
Sergio
Jan 27, 2016 04:27 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:33 PM
