match stock tire size
Old Aug 8, 2008 | 06:56 PM
TJ Chapman's Avatar
i want this set of 18x8.5" 56mm offset and 19x10" 79mm offset c6 replicas for my 99 z28 i think 245/40/18s will be the same size as the stock tire for the front what is a 19" tire size that is the same or close to the same diameter as stock for the rear??
also will i need spacers? and how big for front or rear?
Old Aug 8, 2008 | 11:16 PM
96 Z 28's Avatar
245/40/18 is fine
Based upon tire calculators 295/30/19 is what you need for the rear, although with a 76 MM offset i suspect you'll have issues with fitment
Based upon the FAQs it looks like the most offset you can achieve is 62 MM, basically I assume the backspacing is very minimal at that point and the wheel just won't fit
Old Aug 9, 2008 | 12:09 PM
TJ Chapman's Avatar
hmm well they mention needing spacers to fit the rears on fbodies but i never want to totally trust those ebay wheel companies just wondered if anyone knew for sure
Old Aug 9, 2008 | 12:20 PM
Did you read the post "stickied" at the top of the Wheels and Tires forum listing, detailing what is required to put the C6 wheels on a 4th Gen. It gives you the thickness of the required spacer for the rear wheels. Or is that the source that you don't want to believe?
Old Aug 9, 2008 | 12:28 PM
bluz28's Avatar
Lightbulb
For the rear wheels a set of 1.25" hub spacers would give you the equivalent of a + 47.75mm offset for a +79mm offset wheel, and a +44.75mm offset with a +76mm offset wheel.
So get a 1.25" hub spacer/ wheel adapter.
Old Aug 9, 2008 | 02:39 PM
TJ Chapman's Avatar
yeah i suppose i could have read that huh??? wasn't even sure if the replicas were stock C6 offsets but i spose thats in there too. well thanks to the rest of ya for the help now all i need is to whip out the old plastic n go for it
G-force KDW 2's???
Old Aug 9, 2008 | 08:00 PM
bluz28's Avatar
Thumbs up
Sent you a pm.
HectorM52
Jul 30, 2017 11:46 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
bossco
Nov 29, 2014 10:18 AM
TechCam97
Sep 12, 2002 07:20 PM
