match stock tire size
i want this set of 18x8.5" 56mm offset and 19x10" 79mm offset c6 replicas for my 99 z28 i think 245/40/18s will be the same size as the stock tire for the front what is a 19" tire size that is the same or close to the same diameter as stock for the rear??
also will i need spacers? and how big for front or rear?
245/40/18 is fine
Based upon tire calculators 295/30/19 is what you need for the rear, although with a 76 MM offset i suspect you'll have issues with fitment
Based upon the FAQs it looks like the most offset you can achieve is 62 MM, basically I assume the backspacing is very minimal at that point and the wheel just won't fit
For the rear wheels a set of 1.25" hub spacers would give you the equivalent of a + 47.75mm offset for a +79mm offset wheel, and a +44.75mm offset with a +76mm offset wheel.
So get a 1.25" hub spacer/ wheel adapter.
Originally posted by Injuneer:
Did you read the post "stickied" at the top of the Wheels and Tires forum listing, detailing what is required to put the C6 wheels on a 4th Gen. It gives you the thickness of the required spacer for the rear wheels. Or is that the source that you don't want to believe?
G-force KDW 2's???
Brandon Wittmer
Dec 20, 2014 09:51 PM
bossco
Nov 29, 2014 10:18 AM
