hub centric v. lug centric/section width v. tread width
Old Feb 20, 2007 | 01:05 AM
maro z28's Avatar
Couple quick questions:
Somebody explain lug centric to me, please. I don't even know how to put into words what exactly I'm confused about. I understand a hub centric wheel is position precisely about the hub, I just don't get how a lug centric wheel is positioned by the lugs.
Also, what is section width and tread width? I imagine tread width is the distance from the outer edge of the tread on one side of the tire to the outer edge on the other side of the wheel. Section width must also include the smooth part on the outer edges of the tire? I don't know, just want to be sure. Thanks!
Old Feb 20, 2007 | 01:44 AM
Zack's Avatar
lug centric centers the wheel on the lugs. tuner wheels are lug centric because most come dual drilled for more applications and are used on lots of cars with different sized hubs. this is wear hub rings come into play to center them on the hub
tread width is the width of the tread
section width is distance from sidewall to sidewall
Old Feb 20, 2007 | 11:19 AM
Lug centric centering can be accomplished in two ways. The stock F-Body wheels are centered by the taper of the conical lug nuts, fitting into a matching taper on the wheel hub holes. Drag wheels or some other alloy wheel designs often use a "shank" style lug nut to center the wheel. The holes in the wheel hub are oversize, and the "shank" of the lug nut screws down into the hole to center the wheels.
Info on what tire dimensions mean are in the FAQ.
AviatorDave
Dec 19, 2016 06:35 PM
2QUIK6
Sep 17, 2016 02:31 PM
Pestilence
3rd Gen / L98 Engine Tech
Aug 18, 2015 10:16 AM
Boss002
Jul 24, 2015 10:47 AM
Slayer
Jul 4, 2015 03:06 PM
