offset/backspacing questions
Old Feb 20, 2007 | 12:54 AM
maro z28's Avatar
Taking offset=backspacing-(rim width/2)
Your basically taking the backspacing minus the wheels centerline. So, if the answer is negative then you have a negative offset. Positive answer would be positive offset and an answer of zero would be zero offset, correct?
Old Feb 20, 2007 | 11:23 AM
Yes, but the "rim width" in your formula is not the nominal width of the wheel. It includes the nominal width of the wheel, plus the two flanges that hold the tire bead on the rim. The nominal width of the wheel.... e.g. the 9.5" on a 17x9.5" wheel..... is measured at the points where the beads seat on the rim. A 9.5" wide wheel will typically measure 10.5" wide overall.
Its all covered in the FAQ, with diagrams included.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
