HELP!! 17x11" TT2s w/ nitto 315s don' fit!!
Tried to put my tt2s on and when I tighten them up they nudge up against the frame in the rear. How much spacer can I put on the stock studs?? Should I just get new studs??
Anyone else have this problem
Re: HELP!! 17x11" TT2s w/ nitto 315s don' fit!!
The TT II's for the 4th Gen have a 7.75" backspace. That should not put the tire into the frame. Is it possible your tire is hitting the corner of the jounce bumper bracket? That is only a problem when the car is jacked up by the body. When the axle drops the tire hits the bracket. It's very easy to cut the edge off the jounce bumper bracket if that's the problem. Shouldn't need a spacer.
Moving to "wheels and tires"....
Is the tire hitting inside the wheel well? if so you just have to get a Hammer and pound out the well a little.
If you plan on using spacers you are gonna need to get some new studs. ARP has some that are long enough.
Well, it is my dad who is testing the wheels on the car back at home. The car is on a hoist, therefore the axle is as low as it can go. It probably is hitting the jounce bracket.........but its hard to see this over the phone, lol. My dad seems to feel that when the suspension is at full travel, ie going over a bump, the wheels are going to rub anyways. He is in favour of getting some spacers. I am picking up some spacers and longer studs for when I go home this weekend. I know we will get them to work........I will post the results.
Thanks for the Help
Jeremy
Thanks for the Help
Jeremy
Thanks for the Help
Jeremy
Thanks for the Help
Jeremy
The problem with me putting the wheels on by jacking the rear axle up is that I use this hoist all the time to do work on the car. I also use a floor jack alot to get the car up in the air.
Like I said before, because I am not physically there to see whats happening I dont know for sure. Does anyone have some pictures of where you can cut some **** off to make them fit??
But all you do is cut the edge off the jounce bumper bracket, and the whole problem goes away.... you can jack it any way you want.
http://cjcfo.fbody.com/members/injun...A/FendMas2.jpg
This is a ZR1/GS 17x11 with almost 8" backspace, and a pudgy BFG 315 Drag Radial on it. You've got to have another 1/4" clear. Unless the body is so far off center that one side is into the inner fender and the other side is clear:
http://cjcfo.fbody.com/members/injun...C/TirClr1R.jpg
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
